Need Help!!! Immediately
Old Apr 19, 2006 | 05:53 PM
Jonniwatts's Avatar
Upgrade
I don't know what the hell it is, but there is a liquid inside of my wheel wells, and it hasn't rained for weeks here, i'm think that my brakes are spaying fluid out, and it stinks. Its in all 4 wheel wells, so my question is; Are my brakes going out, and if so what is going on?
Old Apr 19, 2006 | 06:20 PM
saiko_cl_duck's Avatar
does the fluid itself stink, or are you just saying it stinks cause there's fluid?
Have you done any work recently on your brakes?
Old Apr 19, 2006 | 06:21 PM
kraftey's Avatar
Did it happen randomly? Or do you think something could have triggered it?
There is the brake fluid bleeder on the brakes, maybe the rubber cap came loose and it's not tight enough? What color is the liquid.
Old Apr 19, 2006 | 06:23 PM
if the rubber cap came off, it still wouldnt cause fluid to spray, unless he screwed with them and didnt tighten them back down.
5-speed's Avatar
4x4- fat chicks cant jump
all four at the same time would be an amazing coincidence, but i dont guess its impossible
you didnt happen to use tire wax recently, did you?
Old Apr 19, 2006 | 06:26 PM
jonni, just a thought, is the fluid on the inside of the rim itself? If there is none there, i dont think its the brakes
Old Apr 19, 2006 | 06:38 PM
kraftey's Avatar
I'm efficient. I tackle every possible scenario!
Haha... yah I doubt it also.
Old Apr 19, 2006 | 06:47 PM
Jonniwatts's Avatar
Upgrade
I don't know how this happened, i know earlier i pulled my e-brake, then i let it down while i was in neutral, then i take my friend to work. while on the way back i hit a bump and it felt real funny, like one of my wheels were about to fall off, so i creep all the way back to my neighborhood. I take another friend somewhere, and go pick my friend up that i dropped off at work, when i get back to the hood i notice the liquid in all wheel wells, and its also inside the rims, it smells like what ever it is, is hitting the rotors, causing some funky smell
I usually never pull my ebrake, i haven't had any service to my brakes recently, and i can't tell what color the liquid is
Old Apr 19, 2006 | 06:48 PM
Jonniwatts's Avatar
Upgrade
Old Apr 19, 2006 | 06:55 PM
Jonniwatts's Avatar
Upgrade
i jus looked at it, the liuqid is yellowish, maybe tan
Old Apr 20, 2006 | 12:55 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Check your brake fluid level to see if it went down. How do your brakes feel. If they feel spongy or like your not gonna stop, you have a serious brake issue.
Thats the only liquid that it could be that would be on all 4 sides, but your ebrake would not have triggered anything because that is set by a cable. Not hydraulics.
Old Apr 20, 2006 | 06:00 AM
5-speed's Avatar
and only locks the rear wheels... I think
Old Apr 20, 2006 | 09:15 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Old Apr 20, 2006 | 11:45 AM
ib_jimmy's Avatar
maybe u hit an animal.
Old Apr 20, 2006 | 12:26 PM
Jonniwatts's Avatar
Upgrade
My car stops like normal, but i also hear a clunking noise when i turn now, but i'm takin it to the shop today, and see what they say
Old Apr 21, 2006 | 11:11 AM
732xghost's Avatar
that could be your wheel bearing, does it sound like a grinding noise. one of my wheel bearings went after i replaced my rotors and pads.
Old Apr 21, 2006 | 11:51 AM
SwervinCL's Avatar
Nom Nom Nom Nom
cv boots without a doubt
Your gonna need new axles.
Old Apr 21, 2006 | 12:04 PM
amarklham's Avatar
9th Gear
maybe bad tie rods or tie rod ends, either way get it checked out fast.
Old Apr 21, 2006 | 02:48 PM
ajtcl's Avatar
Peace, Love & Acura
Clunk could be CVs, but brake fluid isn't yellowish... I thought that shit was red. At first I thought you might have drainage from something, but YELLOWISH fluid, nope I am lost on this one.
Jonniwatts's Avatar
Upgrade
took it to the honda dealership, they said it was nothin, but it was brake fluid in the wheel wells, and i guess my mind was playin tricks on me about that clunkin sound, jus a lot of bad shit has been happening to me as of recent, but thanks everybody i appreciate everything
Feb 25, 2020 09:57 AM
knight rider
Mar 4, 2016 08:59 AM
hrothgar02
Sep 28, 2015 11:08 AM
STL TL-S
Sep 23, 2015 08:52 PM
