Need help. (((brakes)))
Old Aug 25, 2009 | 09:55 PM
1StealthCL's Avatar
Question Need help. (((brakes)))
ok, so I decided to do the OEM upgrade for my front brakes using the legend calipers and prelude Vtec rotors.
now my problem is, I ordered the Dual-piston calipers for a 1994 Acura legend GS 3.2L sedan. (I was told by many different sources that these were the calipers to buy.) Anyway, when I picked them up from the autoparts store I noticed the caliper mounting brackets say "28T" instead of "23T" and I was wondering if this is the right bracker/caliper or not?? and will it work or not??
any help from the all knowing "Guru's" of Acurazine would be greatly appreciated. I need new brakes urgently and am hoping to do them this weekend.
Old Aug 25, 2009 | 10:42 PM
Anhedonia's Avatar
ok well my two cents is to stop posting the same question in every single subforum and wait for someone to answer your question. im sure someone on here knows, just because you dont get an answer in 10 minutes doesnt mean you wont get one. if your waiting till this weekend to do it, then youve got nothing to worry about and a little bit of time.
chances are, it will be fine. you can always try it, and if it doesnt fit, dont force it. if your at all mechanically inclined, you should be able to tell when something doesnt quite line up
Old Aug 26, 2009 | 09:17 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You don't need multiple threads, the calipers bolt up to the 23T bracket, so chances are you will need those brackets, there's also a diy in the diy/faq section that describes the brackets, try looking at info that exists
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
