my low car is even lower!!
Ok today i go to a totally different shop and complain about this creeeking noise i hear when i go over speed bumps and when i hit the gas and when im driving slow or shake tha car... soo as he's checking out that problem he told me my bumpstops were never cut when the springs were put on? So he took it all apart in like 45min and cut the bump stops...also got rid of the noise something to due with the rear part of the front camber kit and he took apart the shock or sum shit i dunno it was complicated what he said...soo now im driving to school and stuff i would never scrape on, now i hear "CCccccccchhhhhhhkkk" in the front? Why is my car lower now? Front wheels tucking...Do i need new alignment? IS this bad scraping the front? whatz scraping i think its the plastic
Old Man
Your suspension has more travel due to cutting the bumpstops, therefore your car may be lower because the suspension is not sitting on the bumpstops... Also, it sounds like (just speculating) the last mechanic didn't seat your springs correctly.
It would be a good idea to get an alignment, because your car is resting at a different position.
Stylin CL
After i took the bump stops out on mine, i noticed it making a noise like that. On mine its the tire rubbing on the outside of the fender, but thats only when i make turn or go over a bump with the wheel turned.
Hmm actually it might be the tire hitting the fender...didnt think of that cause it happens when im going down into a ditch or making hard turn... I thought it would be weird to scrap because if anything my car is maybe 1/6 of an inch lower, and i barely ever scraped the front before that...Epoc, How low was your drop? And is it ok to hit the fender like this?
The bumpstops are there to keep your shock/strut from bottoming out on full compression, your springs are there to hold the car up. The ride height should not change due to the bumpstops. I'd say your car is sitting lower due to an installation difference, like someone said, maybe the springs not being seated correctly etc.
The movement has started
could be that the springs werent seated rite..the bumpstops would make no difference in the height only the way it ride..my car is pretty low.. i scrape the floorpan while drivin down the road..just sumthin u need to deal with having a lowered car
actually while driving bump stop will make a difference because when you go over a speed bump your suspension will be able in compress more due to then shorter bump stop, as where before he had them cut he hit the bump stop which made the creeking noiseand stoped it from comtracting to much. he never said it looked lower so im guessing thats what happened in his case
Stylin CL
I'm running spotlines with tokico adjustable. The bump stops will make a difference in ride height if the drop is low enough, but that is only when the car is sitting on the bump stops (which happens to be the case with the sportline drop). I don't know what problems this is going to cause, but on my car i have almost worn through the plastic lining on the fender and i will be hitting the metal pretty soon, so i might just put the bump stops back on to prevent this.
hahah my whole suspension just changed my front use to be flushed and back use to be tucked tucked... now with my bumpstops cut (like they shoulda been) front tucks...and i took the system out soo back is flush heheheh
MaCe which camber kit u got? and how is the ride nowadays? (as in suspension)
fellow MASShole
i have an ignalls kit ... ride is ok gettin a little bumpy i guess and i swear the dayum thing is gettin lower as time goes by im startin to rub all over the place
roomate has a CL too
Shit I think this thread is giving me more confirmation about getting Tein SS. Thanks for the updates and sorry about your troubles.
fellow MASShole
seariously ... if i could do it over ide get teins my pricing was as follows :
sportlines 220
tokico blues 320
ingals 150
install 150
alignment 220
totaling =1060 YIKES
plus - i have an uneven lookin drop ( back looks lower than front because of or car design )
- any snow and im a plow luckily i have a old s-10 that i rock during the winter
spend the money go teins all the way
sportlines 220
tokico blues 320
ingals 150
install 150
alignment 220
Trust me I spent way over 1k on my suspension
I could be on bags right now for all the money i spent...I funny thing is I paid alot more then 150 for my camber kit and it sucks...I think i paid almost 400 for front/back sprint camber kit i got rippd off and im trying to make the place that i got it from pay for an ingalls in the front cause my shit sucks...They freakin orderd it off of nopi.com its like 107.01/side in the front and 90.00/side in the back all i knew at the time was my tires were wearing. Wish i woulda researched it more...Plus they charged me mad dough for installing fug them whatever.
even if you went with teins you would still need alignment, ingals, and install. which is about half of the 1060 anyway
sportlines 220
tokico blues 320
ingals 150
install 150
alignment 220
sportlines 220
tokico blues 320
ingals 150
install 150
alignment 220
fellow MASShole
yea no shit ... 25 maybe for a regular car ... 225 was for a 4 wheel alignment plus camber kit install .. i know its a little high but its the only place in this area that would do it ..
and ive only had 1 so far and shes still drivin nice and straight
acura-cl.com OG
baka_t, damn your car is low! I have a prokit and it still looks stock, wish i went with real coilovers, either apexi or tein. Question though, when you get a camber kit with coilovers, does that make it in specs at whatever ride height you want, or just one specific height?
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
