My latest purchase.....
Old 09-25-2002, 08:00 PM
Swaps? $3000 for 50HP? :(
niedejb's Avatar
No need to dyno when changing fuel set up anymore....moblie wideband O2 sensor :P
Old 09-25-2002, 08:44 PM
cmng 2 a lawschool near u
KC CL 1785's Avatar
Can you elaborate a little more? You know for those of us that aren't Car modmasters
Old 09-25-2002, 08:47 PM
niedejb's Avatar
It measures air to fuel ratio per rpm similar to a dyno.
Much better than the air to fuel gauges that are out there....theyre not fast enough to be accurate (like my apexi turbo timer O2 a/f readout)
Old 09-25-2002, 09:07 PM
ENGAGE MY VTEC BABY!!!!!!
97Acura3.0CL's Avatar
tell us where you got it from so other can get in on this find? how hard to install it? how much was it and any details?
Old 09-25-2002, 09:15 PM
niedejb's Avatar
Got it here.
I had to have one bung welded on my downpipe already for $20...this is just another bung.
Way expensive....$750, but thats 5 hours or so of dyno tuning....with the AEM EMS I'm wanting it'll be a wash for tuning it.
Rumor has it that new EMS will have auto tuning with wideband O2 sensors.
Old 09-26-2002, 07:25 AM
AkA 'Lucky'
BLACKOUTCL's Avatar
Originally posted by niedejb
Got it here.
nice mod
when is the new EMS coming out??
just wondering why you choose AEM over others like sds or hondata??
Old 09-26-2002, 07:49 AM
niedejb's Avatar
Didnt consider sds.
The cost of Hondata 4B+ datalogging + converting to OBDI + new ECU is if not the same more than the AEM EMS.
With hondata you have to burn roms everytime you change your map....no thanks. AEM EMS is plug and play....no wiring nightmares.
The ONLY thing I've heard that the EMS cant do is function as a turbo timer.
It will control boost that Hondata wont. Can you imagine varying boost pressure based on speed? Traction!
Old 09-26-2002, 11:56 AM
AkA 'Lucky'
BLACKOUTCL's Avatar
Didnt consider sds.
makes sense because of your boost, didn't know hondata doesn't control variable boost, i assumed they all did
i just got off the phone with AEM about the ems and the new system is called the race system and it's identical to the one out now but doesn't come with a harness, it has to be spliced from factory harness.
am i missing something?? when i do the h22 swap, will i be able to use the ems direct plug and play?? will the wires be the same?
the tech didn't have a clue??
Old 09-26-2002, 06:18 PM
niedejb's Avatar
You should be able to use the EMS for the H22 which is the same part number as the F22 if I remember correctly.
Dont get the race system. Get the plug and play.
mlody
12-04-2019 02:11 PM
knight rider
03-04-2016 08:59 AM
AZuser
09-17-2015 10:15 AM
ostrich
09-11-2015 04:28 PM
Quick Reply: My latest purchase.....
