My Idle is out of control
Old Aug 20, 2006 | 03:45 PM
732xghost's Avatar
my idle saga began in the summer of 05 when every now and then my idle would drop then surge then drop again, it didnt happen to much so i over looked it, then in the end of the winter it would get really bad and would happen on a daily basis. so i finally did something about it and me and arber (supraman) cleaned out my IAC, then the problem went away for about 4 months. then it came back. not to mention this makes my car sound like shit because my heatshield around my cat and my exhaust rattles like a mother fucker especially with the A/C is on and when i got my Greddy exhaust. its really embarrasing when im just sitting some where idling, every other jerk off is like dude whats up with your car. obviously if i just take out the heat shield all the rattling will go away. but i cant figure out WTF is going on with my idle. i doubt its all clogged up again and if it is that would really suck. maybe i need to replace the IAC. so any of your opinions would be appreciated, im also gonna check in with the genius' at honda-tech. thanks
Old Aug 20, 2006 | 04:00 PM
732xghost's Avatar
ooo and i forgot. i just put on my magnecor wires i ordered off ebay for an Accord and my idle tends to be worse now. could that be because im running with conventional spark plugs, do i need iridium's???
Old Aug 20, 2006 | 04:53 PM
lcstyle's Avatar
Loose Cannon
just replace the IAC valve bro, obviously your current one has already been cleaned and it sounds like it has seen better days...
Old Aug 20, 2006 | 05:57 PM
732xghost's Avatar
i did clean it out already, yea im thinking i might need a new one. i guess when i go to work tommorow ill see how much i can get one for.
Old Aug 20, 2006 | 07:09 PM
TexasHonda's Avatar
Also clean the inner throttle body and throttle plate (front and back) carefully. Depending on how the IAC was cleaned it may have clogged again. You have to remove and really flush the cavity w/ throttle body cleaner a number of times to get all the gunk removed. It could be faulty so check the solenoid driver to see if it's open.
good luck
Old Aug 20, 2006 | 07:17 PM
98 CL's Avatar
smoked by a Focus
I had the exact same shit going on in my car. Surging idle, and every dumb-ass kid thinking I was trying to race them at a light. I tried to clean it first also and it didnt do much. I had to replace the IAC altogether, which was easy since I had bought an extended warranty with the car. I'm fairly sure that is your problem/ solution.
Old Aug 20, 2006 | 07:20 PM
732xghost's Avatar
well my idle never surges that high, it idles really low and drops even lower.
Old Aug 20, 2006 | 07:49 PM
livinglegend's Avatar
ULOOZ
Cool
Replace the IAC/rotary valve.....
Old Aug 20, 2006 | 09:40 PM
SupraManAG's Avatar
One custom CL
sea foam
im looking to do it
u down Matt?
Old Aug 20, 2006 | 10:53 PM
danielsmi's Avatar
seafoam!!
Old Aug 21, 2006 | 11:32 AM
732xghost's Avatar
Originally Posted by SupraManAG
sea foam
im looking to do it
u down Matt?
im down just let me know when?? im off tommorow and wed. but i have orientation for college till 4 on each of those days, but im off on sunday. and i get out of work everyday at 5. so just let me know, i still didnt get my camber kit in either, but ill let u know when i do.
knight rider
Mar 4, 2016 08:59 AM
DerrickW
Nov 15, 2015 05:52 PM
adreano17
Sep 29, 2015 08:48 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
