My car is over heating
My car has been over heating lately but i can't seem to find out what it is. I look to see if maybe it was that it had a raidiator leak but it doesn't seem to be that. And the hoses seem good to does any one have some type of idea on what it my be?
if u are not loosing any coolant it is likely your water pump or thermostat. If u are loosing coolant out of your reservoir it is probably a head gasket. I would get it looked at so u don't cook a head gasket because of a sticking thermostat.
I had a couple overheats... 2.2... I flushed the fluid and got a new cap- overheated again... then i changed the thermostat- it overheated again... Then i did nothing and it hasn't overheated since... Works for me!
I blew my head gasket and my oil was mixing into my cooling system which caused my radiator to crack and my motor to take a swan dive off the edge. I replaced my radiator thinking that it was just cracked and ignoring the diaria looking substance running within. that caused lots of problems. That was not fun cleaning. Make sure there is no oil in your cooling system. Catch up with it before it catches up with you.
