msd ignition
Old Sep 19, 2005 | 05:36 PM
Bigpimpin18's Avatar
Soon to be H22 turbo!
msd ignition
ok guys, i just installed my new msd ignition. It consists of msd modified ditrobutor cap, nology hottwires, ngk iridium plugs, msd 6A ignition box, Blaster 3 coil. Wut happens is at like 5-6K RPM my car jerks and has a crackle. I called MSD tech's and they said to see if the coil is arcing or the box is arcing. Could there be anything else that's wrong.
I have a 1997 Acura 2.2CL
Old Sep 19, 2005 | 10:21 PM
ghost_masterCL's Avatar
yep definitely check for arcing, I think agrando had a simmilar problem recently, or it was platano. But it was teh wire's fault. just rev up you're engine manually at the TB and look for sparks.
especially with the 2.x's distributor being so close to the CAI.
Old Sep 19, 2005 | 11:24 PM
wilp99's Avatar
heres a goo diy on how to install it...i know its already installed but maybee he did something different so that arching didnt happen.. check it out.
http://home.insightbb.com/~niedejb/
its under installs.. tho i just checked and its a different brand. but it still should be similar.
keep this link cause theres tons of good stuff on here.
Old Sep 20, 2005 | 09:19 AM
ok last night, I had my buddy follow me, and I got it up to 5K RPM and he said he saw a lil flash out of my tail pipe, but it was only for a split second. There has to be something wrong there. And I didn't see any arcing over the coil, or the distrobutor cap or plug wires.
Old Sep 20, 2005 | 09:16 PM
732xghost's Avatar
what size MM are your hot wires???
Old Sep 20, 2005 | 10:36 PM
damn, unless you are turbo'd I wouldn't see any reason for that. perhaps the spark is too hot and it's causing your exhaust gasses to heat up too much and burn up the catalyst in the catalytic convertor. go to you're local pep-boys or something and see if there is a stored CEL code. The light doesn't always come on, but for seeing a flash coming out of your tail pipe, something had to have been stored.
Old Sep 23, 2005 | 03:04 AM
I have 8mm Nology hottwires, but those things have built in capacitors. Or do you think I should re-gap my sparkplugs? would that do anything? I'm sort of getting frustrated with this, because I don't want my engine to get all fucked up. And I don't want to waste the money on something that isn't workign out too well.
Old Sep 23, 2005 | 03:43 AM
wilp99's Avatar
shoot your timing, it sounds like its advanced.
Old Sep 23, 2005 | 09:04 AM
and if it is, how would I retard it? should I still check my spark plug gap?
Old Sep 23, 2005 | 09:27 PM
I checked my timing today, it's good. And my autoshop teacher told me that it may be my catalytic converter has something bad in it. since i already have an exhaust on the way. I'm going to buy a catalytic converter, which kind does the best for our car. I also want to buy headers, are these ok DC sport headers
Acura604
20
Aug 5, 2017 12:55 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
malvothegreat
Sep 29, 2015 12:38 AM
h22lude
Sep 27, 2015 06:22 PM
