Max ammount of drop without camber kit
Old Jan 5, 2007 | 01:09 PM
civic_slayer's Avatar
Hey I was thinking about getting coilovers but dont have the money right now to buy a camber kit so I was wodering how far can I drop the car without having a camber kit.
Thanks,
Charlie
Old Jan 5, 2007 | 01:31 PM
klepto's Avatar
about this far :gheylaugh:
camber kits, who needs em?
Old Jan 5, 2007 | 01:35 PM
mugen_moby's Avatar
remember safe sex
You must not like your tires very much.
Old Jan 5, 2007 | 01:37 PM
klepto's Avatar
they've actually been holding up well. my control arms and downpipe hate me the most.
Old Jan 5, 2007 | 01:38 PM
PimpCL23's Avatar
contrarian in fashion
I had a -2.75 degree camber problem... i went thru tires every month and half to 2 months!... got annoying so i got tha damn thing aligned!
nice pic BTW Klept!
Old Jan 5, 2007 | 01:42 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Control arms, balljoints, downpipe and exhaust pipes are what take the most abuse.
Old Jan 5, 2007 | 02:16 PM
zguy95135's Avatar
I dropped my car like Klepto's, and I put nearly 10k miles on my new tires and they still have plently of tread. Although I have a feeling I will be needing new ball joints sometime in the future...
Old Jan 5, 2007 | 02:27 PM
zguy95135's Avatar
Sorry to thread jack... but I get a slight clicking noise coming from the right rear wheel well when I accelerate or downshift, I thought it was the jack rattling around, but I took everything out of the car and it still does it sometimes. No weird vibrations or anything so thats good.
Maybe its time to get some bigger wheels and coilovers.
Old Jan 5, 2007 | 02:51 PM
klepto's Avatar
sounds like a good plan to me. although its gonna be totally different slamming your car with 18's as opposed to the smaller wheel's youre on now
Old Jan 5, 2007 | 02:59 PM
zguy95135's Avatar
Yea, I like riding slammed on 16"s but having to replace axle's and ball joints every 6-12 months isn't that appealing
I've been looking at 17" and 18"s, I like the way GarfieldwithCL's car rides and I think he just has 17"s. Plus I've already got Illuminas so I could just buy some Ground Controls and be happy with that.
Old Jan 5, 2007 | 03:02 PM
PimpCL23's Avatar
yea.. they 17s
Old Jan 5, 2007 | 03:17 PM
732xghost's Avatar
your boot is porbaly torn on your passenger side axle.
Old Jan 5, 2007 | 03:45 PM
anyways to get back on topic here ya buncha thread jackers how far can I drop to keep it within specs
poor college student=no money for new tires
Old Jan 5, 2007 | 05:04 PM
AznX TL's Avatar
where is....
umm did you ever take off the tire and check the inside tread? when i traded wheels with art, my tires were completely bald on the inside down to the wire.
Old Jan 5, 2007 | 05:06 PM
AznX TL's Avatar
where is....
are you going to get springs or coilovers? springs arent adjustable. a camber kit wont cost you too much, but the labor cost of getting the springs installed will rape you.
Old Jan 5, 2007 | 05:42 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Its so easy to do yourself... I went to Harbor Freight Tools and got the spring compressors, they cost me like 12 bucks I think... They have a hydralic one for like 50 bucks, but I have a compressor so I just got regular ones..... I think my front took me like 30 min a piece. My back took me like another 30 minutes the next day.
Old Jan 5, 2007 | 07:41 PM
(Mid-Atlantic)
Just get a camber kit for like $100 and save on tires
Old Jan 5, 2007 | 07:50 PM
zguy95135's Avatar
mhm, still lots of tread.
Old Jan 5, 2007 | 08:13 PM
wilp99's Avatar
1.25" drop on my cl and i was barley outside the limits.
Old Jan 7, 2007 | 05:32 PM
sd97cl's Avatar
Do 3.0 springs fit on a 2.x?
Old Jan 7, 2007 | 05:45 PM
AznX TL's Avatar
where is....
yes but it wont be the drop you expected because the 3.0 is heavier, if it was designed for the 3.0 then the drop will be less than what you expected. but if it was designed for the 2.x and you're gonna put it on the 3.0 the drop will be more than you expected.
Old Jan 7, 2007 | 08:12 PM
(Mid-Atlantic)
Read the n00b guide
Old Jan 7, 2007 | 08:19 PM
Cocoa's Avatar
2600lb CL
Possibly the wheel bearing? Lift the car up and see if you have any play with the wheel. If so, then the wheel bearing should be replaced.
Old Jan 7, 2007 | 08:20 PM
Cocoa's Avatar
2600lb CL
he said rear wheel though, but maybe the noise is coming from the front. Sometimes it is hard to distinguish.
Old Jan 7, 2007 | 08:45 PM
zguy95135's Avatar
It shouldn't be an axle or boot, I just got them replaced like two months ago... I'll check and see if its the wheel bearing tomorrow though.
Old Jan 8, 2007 | 07:27 PM
zguy95135's Avatar
I have good news and bad news:
The good news:
I checked the wheels, its not the ball joints or any bushings. I don't think my axles or CV joints are bad either.
The bad news:...
I think its my transmission >_<
http://www.youtube.com/watch?v=dQoBfU33F-U
The first cut is with the car in neutral, and the second is with it in gear. It sounds like its coming from inside the transmission, not the CVs (I know what that sounds like, unfortunately). The weird thing is that my transmission doesn't slip, grind, or have any problems going into gear. It just makes some noise sometimes when I accelerate from a stop or downshift... wtf
Old Jan 8, 2007 | 10:51 PM
5-speed's Avatar
4x4- fat chicks cant jump
hmm... pull out the axle next time you have the time (and tools, for that matter) and see whats up with them. does it do it on the other side too?. maybe time for a new clutch? i dunno
Old Jan 8, 2007 | 10:56 PM
zguy95135's Avatar
Yea the other side sounds exactly the same. I'm home for another four days so I'll see if I can pull the axles out and see whats up... >_>
Old Jan 9, 2007 | 01:12 AM
wilp99's Avatar
honestly that sounds normal.. all thats right inside there is the differential.. which is surrounded by two bearings right were the shafts go in. thats all mechanical gears right there. if there was a problem there it wouldnt slip. it would grind while turning or have a huge clunk when you go into gear. was the entire front end off the ground (both tires)
eastsideride
Oct 15, 2015 04:26 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
4drviper
Sep 23, 2015 07:42 PM
0opie
Sep 22, 2015 04:15 PM
nuldabz
Sep 3, 2015 05:49 PM
