Manual Differential Oil Replacement?
I tried reading the freakin manual but it doesnt tell me much...I also tried searching the old posts and nothing.
How do we replace the differential fluid on the 97 2.2 manual transmission? I just replaced my drive axles and some of the fluid leaked out. There are also two drail/fill nuts on the differential. Where can i find the procedure to do this job? And what weight oil does our tranny accept?
thanks
thanks
Put in Honda Manual Transmission Fluid or GM/Penziol Synchromesh.
To drain, un-do the bottom bolt that has a 3/8th" recessed square type head. Replace and tighten.
To fill, un-do the upper most bold (14mm or 17mm i believe) and put in fluid. You might need a hand type pump or a funner with a long skinny tube running from the engine bay to pill. It holds 2 qts.
Thanks for the info..
but what type gear oil do i need to fill with? What weight? I couldnt find that in the manual..Or should i just goto Honda dealership and pick up two quarts of their differential oil?
thanks
mc
thanks
mc
Many People have used the GM/Penziol stuff and had no problems or its been better than the Honda Brand MTF.
Megaman: Its doesnt say a weight on the bottles of the Honda or GM/Penziol brand!
This is what the bottle looks like:
Part Number: 08798-9016
Price: $6.76 from Tampa Hondaland, price might be a lil different depending on the dealer.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
asahrts
09-04-2015 05:55 PM
