maintance required light
I was driving today and my maintance light turned red, and when i bought my car the dealer said that the 60000 mile checkup had just been performed. My milage now is 66500 and i havent even gone 3500 miles since my oil change. Any comments.
thanks ill try that, any other comments on what else it could be. the car runs perfect, so i have no clue as to why it would be on. Also i wouldnt bother with this had the dealer given my the correct manual to start with
its not a light
I took apart the gauges as most of u know and did an extensive report on it
The maintenance light is controlled by the mileage odometer, like every 100 miles or so, the maintence odo turns one notch. So after enough miles, the color changes
It's a green, then yellow, then red change. It spins, no electronic light involved. So yes the key thing will work. It basically lifts the lock on the notches, and resets it back to the beginning green. I believe it goes off every 7500 miles? My guess
Do the key thing ...Don't drive to long without resetting it after it turns red because you risk the chance of breaking it when you reset it because it gets stuck and you have to push the key in harder to get it to reset...
60000, or around there if i remember correctly, when i took it in the computer said i need ed a new egr valve, and a valve job, fuckin egr ran 400.00!!!! plus 200 install! hope you dont have the same luck...
It's not a light, or any other kind of electronic devise!
It's an indicator that is mechanical in nature.
Just put your key into the slot, and it'll go back to green.
It turns to red @7500 miles.
mada51589
Jan 9, 2025 04:40 PM
Greengecko
Sep 16, 2015 08:19 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
