MAF help..
1 Post
MAF help..
So the f23 has a 3 wire MAF sensor.. the question is, which one is actually the sensor data one? I tried the green one (figured it would be color coded... guess not) and that was a no go.
for the sake of not splitting into the other two wires rambo style, i figured id ask.
where is....
http://www.acuraautomotiveparts.org/...s=&view=normal
are you wiring an a/f gauge up?
1 Post
yep trying to diagnose/keep an eye on why im running so lean..
According to the writing with it, its working properly (reading rich until warm up) but i wont know for sure until i leave for work in a half hour.
Also wired up a Voltmeter, I cat stand how little information the stock dash display gives you.
1 Post
and i read the top of the sensor, it does say MAP..
good job acura of milford. real winners over there. i musta argued with the guy for close to 45 minutes about it being MAP vs MAF
1 Post
Mini hijack. My radar detector has a low voltage warning and when I turned it on my radar detector was shutting itself off because it was reading my battery as too low. I think it was like 11.9 what should the voltage be? Time for a new battery? It's been in there the 3 years I've had it.
1 Post
Well, normal battery's cycle around 12volts when the car is off, and 14 when the car is running.. if your car is running and only cranking out 11.9, id suggest a newer battery, possibly with a higher CC amperage
1 Post
the HID's are probably whats getting you, your ballasts could be kinda bleh, easiest way is to pick up a voltmeter (not necessarily a guage) and test the voltage around the ballasts, if something is shorting it could be causing them to leech off the battery and wear it down.
then again, it could just be a 3 year old battery
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
TheWrench116
25
11-01-2015 12:24 PM
