Made a big oopsie
Made a big oopsie
Ok so I got my indiglo guages tonight.. I was so excited to install.. Well I made few minor mistakes..
First off I broke the plastice cluster cover.. (Does anyone have any they want to sell?)
I also broke the needle for the gas guage... Yeah I know fuck.. Does anyone know how to fix this or what the cost is to fix this at the dealership? Any ideas.. All is welcome.. I hoep the low fule guage still works without the needle..
Ok well i need suggestions ASAP, I need the fuel gauge to work...
lol.
your supposed to start w/ the temp guage first incase you break the first one
i have an extra cover BUT, you might just wanna buy a whole new cluster off ebay or something since that replacement gauge will be 70-80 if i remember correctly
Originally Posted by Sumaccordguy1994
I should have both around... what year car? the 97 has white needles, 98 and 99 have orange needles.
I have a 99... If you have them let me know that would be fabulous... In the mean time I hope i dont run out of gas any time soon
Guage cluster trim bazel w/ switches
http://cgi.ebay.com/ebaymotors/97-99...05989636QQrdZ1
$18.99 BUY NOW!
$18.99 BUY NOW!
$18.99 BUY NOW!
$18.99 BUY NOW!
I need the plastic clear covering.. for the speedometer and such.... I also need a Gas Gauge...
Originally Posted by shineynitelite
lol.
try that back when i had the Civic. couldnt get to stick.
Yeah I would have to wait for either a full tank or empty tank??? But I guess when the car is turned off.. The needle is in the Full Position.. I could try some supa GLUE... What did you try?
Originally Posted by Motohip
Each guage is independant from one another, so yes, you can replace just one if you need to.
What about on the back side of the panel/board is it soldered in or what. I never went as far as to take off the back side.. i just put it back in for now until i get the parts.. I had to get to work.. Wish i could have used it as a sick day..
Originally Posted by ruin
dont know about the plastic cover ,but u can use the gauges from an accord got it from a junkyard 7$
Any particular Year... I cant find any junk yards that have any CL's good for the CL, not for me.. What year and model Honda would fit this..? What is the back plane look like does it solder in?
94-97 accord gauge cluster
Yeah in doing some digging on Ebay I actually saw a pic of the 94-97 instrument panel and realized it was the exact same one..
I take it the Gauges are plug n play??
I called a place and they will sell the entire cluster for 50...
they are plug and play, and $50 is a good deal, keep in mind that the gauage cluster changes the mileage on your odometer as well
Good News
Ok so I recieved another cluster from a 97 accord.. No problems excpet the brackets werent in the same exact place, But it mounted with minor adjustments. I basically had to install the entire cluster from the Honda, cause the needles were of different color..
But the problem I am noticing is that the TAC-o-meter is getting stuck in certain positions. Does anyone else have this issue that has changed or added face plates over thier instrument panel?
I am told it would cost 250 to mail it out and get this fixed.. What the hell.. Anyone have suggestions or solutions..
Do you have an auto or manual? Is the gauge cluster from auto or manual? If they both match, check all your connections first
The cluster was from a manual.. I have auto.. But when I was working with the original cluster.. After I put the gauge faces on I had issues with that one as well. Like from having to move it to put the face over it... It works, it just gets stuck in certain areas.. And it seems like it goes into a higher range.. Like maybe I messed up motor on it or something....YIKES
u probably got a defected cluster.
I removed the cluster from the salvaged car itself..
Yeah Im not sure..
I would like to have this fixed. But all in all its just cosmetic for the most part.. But i would have to mail it away to a company and it takes like a 10 days to get it done.. I was also quoted like 250 from a car shop to mail it off... FUCKING BIOTCHH
that sux.now get new sh*t and git-r-done.
