Lesson learned
Old 11-07-2011 | 09:22 PM
TAco23's Avatar
Lesson learned
So last weekend I was stuck in a parking lot not to far from my house. Car had been running fine, no issues. Came back from a haircut, hop in my ride and i get a no start, no crank issue.
Seriously stumped and mad (it was my gf's bday and I hadnt gotten her gift yet). In the parking lot I removed the starter with finger nail clippers, an avocado and a tooth brush.
Walked to the auto parts store had the starter tested. Passed. Walked to another parts store, tested, passed.
Re installed starter, figuring it was an ignition issue I just kept trying it. Finally i got something and headed home.
Got home and again a no start. I spent 2 days chasing wires, relays, fuses, pumps you name it. Finally i just bought a new starter, popped it in and havent had a problem since.
Old 11-08-2011 | 08:26 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Been there, done that, bought the T-Shirt.
Basically 1 of the gears in your starter was ground down. If you kept cranking it, it would eventually start. But if you have the new starter, you should be good to go.
Old 11-08-2011 | 07:55 PM
DaInFaMMuS1's Avatar
Originally Posted by 97BlackAckCL;13349974[B
]Been there, done that, bought the T-Shirt.
[/B]
Werd, happened in my 2.3 also
Old 11-09-2011 | 04:49 PM
SupraManAG's Avatar
One custom CL
Hey have u tried that recall on ignition module underkneeth your steering wheel?
I learned that the hard way. One way to start the car is to get a 12 gauge wire and jump your constant power terminal amd your signal terminal on your starter. Nothing wrong with the starter. The key nevernsends the signal to the starter to turn on...
Old 11-09-2011 | 07:12 PM
TAco23's Avatar
I have a safer and easier way to eliminate the relay under the dash. Disconnect the Negative wire on the starter, use a voltmeter at that wire end, and the negative side of the battery, if you get voltage the starter is bad. if you arent getting any voltage your starter isnt the problem, check the relay.
Got this tip a little late for a great mechanic.
Old 11-10-2011 | 02:03 AM
Silence*'s Avatar
Sounds like what happened to me recently, just my starter sounded like a dying cat or something lol. I gave it a few good whack's with a pry bar and it would temporarily fix it. Finally replaced it today, was pretty easy even with recovering from a broken arm.
Old 11-10-2011 | 11:13 AM
on1wheel01's Avatar
Mine will hang up once a year or so. Just have to tap it with a hammer and it's good. But as a backup I saved the starter out of the parts car I bought last year
Old 11-10-2011 | 02:13 PM
(Mid-Atlantic)
cool story bro
Old 12-14-2011 | 12:08 AM
Tragic Bliss's Avatar
EMT
mine did the same thing... but i bought a yellow optima battery an no probs... hmmm
Old 12-14-2011 | 06:31 PM
TAco23's Avatar
Must be nice still living at home. Only then can you drop a hundred+ on a battery.
Old 12-15-2011 | 02:09 AM
EMT
Or maybe three jobs. One in a ambulace as an Emt. One teaching parkour and gymnastics and finally dietary aid at our hospital. Thanks for judging though. Hope you make it through life the way you judge others. Never know who may show up to your car crash. Just saying.
Old 12-16-2011 | 05:32 PM
TAco23's Avatar
You must really suck at all three of your jobs if you dont know the difference between making a comment and judging someone. Please dont show up to my car accident, send the guy that actually knows what he is doing please.
Dont be so defensive, its ok to live in mommies basement.
Old 12-16-2011 | 07:47 PM
EMT
sir i have my own place. and i dont suck at any of my jobs but thanks. if judging or comment it dont matter it wasnt needed. plain an simple
Old 01-22-2012 | 03:15 PM
SleeperishCL's Avatar
Determined Noob
Woah boys calm down. As for my CL, starts just fine! ^_^
Old 01-23-2012 | 07:57 AM
Project_CLean's Avatar
MMkay.
+1 On ignition recall! and those tests that they do at autoparts stores; can't really be conclusive. They just run power thru the starter; but you can't be sure unless you do a physical exam on it as well as go thru the car itself.
Old 01-24-2012 | 03:00 AM
ExShinobi's Avatar
Cool
Yep, goin thru that issue now!! it freaked me out 1 night when i got offa work i turned, no nothin.. knew it wasnt a power issue... i figured it was too cold for the remote start to kick on.. but when i physically got in it just did a clicky sound!?!? i was bout rdy to ish bricks!! but a cpl mins later it started up and i booked it home. it has a small lil issue every now n then, but i needa stop sluffin and get that issue addressed!
Old 01-24-2012 | 03:05 AM
ExShinobi's Avatar
Red face
I know that feeling man... i get harassed by the fuzz quite a bit when i take my chariot out n bout!!! Ppl gotta understand that it aint what the car been through, its what the person been through for the car!!! being a car junkie is a nasty nasty habit... lolol but ohhhh so relaxing at the same time!!
Bobinator
1G RDX Photograph Gallery
17
01-04-2021 01:30 PM
spoiler900
10-10-2015 06:48 PM
MilanoRedDashR
10-02-2015 10:49 AM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: Lesson learned
