LED's
LED's
I just replaced all my interior lights with white LED's. When I was trying to install the ash tray light I accidentally pushed it in and it dissapeared into the housing. There is plastic molding all around the OBDII plug and the ash tray light housing. I cant get my hand in there to push it back through. How the hell do I take off my center consel? I've never replaced the radio or anything like that so I have never taken off the console b4. Is there a DIY for taking it apart?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
There's a diy somewhere, the 2 bolts behind the radio are the hard ones, when I did that, I had to take my hu out to reposition the ashtray light, but i've had an aftermarket hu for 3.5 years so it was easy for me to just pop it right out cuz i've done it a million times
Cool, I guess it looks alot more intimidating with all that old cold plastic. I always act like its glass when i take it apart cuz im afraid ill bust it. I took the whole day off of work to replace my window regulator, ended up only taking like 35 minutes.
IT doesn't even take 5 mins to fix your problem... Here's how you push the led back to its' place:
- First, pop the plastic molding aroudn the radio. This will give you enough space between the head unit and the ashtray's upper part.
- Then you'll see a loose wire (that powers the ashtray light).
- Use your index & middle finger to hold the wire and push it back into place...
- You're done.
- You're done.
thats good to hear. i have a regulator sitting here in my room. haven't had time to install it but if it only takes that long i'll probobly end up doing it sooner than later.
Eggs999bacon
09-24-2015 10:08 AM
