Klepto please add this to the n00b guide!!
I originally tried to send this in a pm but it was 5000 characters to long so I'm doing it in a thread. here goes
I found all this info on acura's website, it's there anymore but google had a cached version of it and I thought it was very informative and that it belonged in the n00b guide. here it is
SPECIFICATIONS for 3.0/2.3CL
Engine Type
3.0-liter, 24-valve SOHC w/VTEC V-6 (3.0CL)
2.3-liter, 16-valve SOHC w/VTEC inline 4-cylinder (2.3CL)
Horsepower, SAE net
200 hp @ 5000 rpm (3.0CL)
150 hp @ 5700 rpm (2.3CL)
Torque, SAE net
195 lbs-ft @ 4800 rpm (3.0CL)
152 lbs-ft @ 4800 rpm (2.3CL)
Redline
6300 rpm
Fuel Cutoff
6600 rpm (3.0CL)
6500 rpm (2.3CL)
Bore & Stroke
3.39 in x 3.39 in
(86.0 mm x 86.0 mm) (3.0CL)
3.39 in x 3.82 in
(86.0 mm x 97.0 mm) (2.3CL)
Displacement
182.9 cu in (2997 cc) (3.0CL)
137.5 cu in (2254 cc) (2.3CL)
Compression Ratio
9.4:1 (3.0CL) 9.3:1 (2.3CL)
Induction System
Multi-point Programmed Fuel Injection (PGM-FI)
Valvetrain
SOHC 24-valve w/Variable Valve Timing and Lift Electronic Control (VTEC) system (3.0CL)
SOHC 16-valve w/Variable Valve Timing and Lift Electronic Control (VTEC) system (2.3CL)
Engine Block
Aluminum alloy
Cylinder Head
Aluminum alloy with 4 valves per cylinder and VTEC
Emission Control
3-way catalyst
Ignition System
Full Electronic ignition
Alternator
12V, 100A (3.0CL)
12V, 80A (2.3CL)
Battery
12V, 72A (3.0CL)
12V, 52A (2.3CL)
Recommended Fuel
Unleaded regular
Body Type
Unit body
Front Suspension
Independent double-wishbone
Rear Suspension
Shock Absorbers
NWS-type (New Wide Setting)
Stabilizer Bars
(3.0CL) Front
Diameter
25 mm (0.98 in) (solid)
Rear Diameter 16 mm (0.63 in) (solid)
(2.3CL) Front Diameter
27.2 mm (1.07 in) (hollow)
Steering Type
Rotary-valve, variable-assist, power rack-and-pinion
Steering Ratio
17.4:1
Steering Wheel Turns, lock-to-lock
3.0
Turning Diameter
39.04 ft (11.9 m)
Wheels
6 JJ x 16 7-spoke (3.0CL)
6 JJ x 16 5-spoke (2.3CL)
Tires
P205/55 R16 Michelin MXV4
Braking System
Front Discs
(3.0CL) Ventilated, 11.1 in (282 mm) diameter, 1.0 in (25 mm) rotor thickness
(2.3CL) Ventilated, 10.2 in (260 mm) diameter, 0.9 in (23 mm) rotor thickness
Rear Discs
(3.0CL) Solid, 10.2 in (260 mm) diameter, 0.39 in (10 mm) rotor thickness
(2.3CL) Solid, 10.2 in (260 mm) diameter, 0.4 in (10 mm) rotor thickness
Total Swept Area
(3.0CL)370.1 sq in (2389 cm2)
(2.3CL)363.9 sq in (2267 cm2)
Parking Brake
Separate parking caliper
Anti-lock Braking System (ABS)
Acura-designed system with four wheel-speed sensors and electronic/hydraulic control unit
POWERTRAIN
Type
Transverse front engine/front-wheel drive
Transmission
Ratios (:1)
3.0CL
4-speed automatic
1st 2nd 3rd 4th Reverse Final
2.534 1.502 0.947 0.608 1.846 4.200
2.3CL
5-speed manual
1st 2nd 3rd 4th 5th Reverse Final
3.285 1.807 1.193 0.903 0.685 3.000 4.062
2.3CL
4-speed automatic
2.528 1.427 0.981 0.620 1.863 4.466
CAPACITIES
Crankcase
4.6 U.S. quarts (4.4 liters) refill capacity, including filter (3.0CL)
4.5 U.S. quarts (4.3 liters) refill capacity, including filter (2.3CL)
Cooling System
9.3 U.S. quarts (8.8 liters)(3.0CL)
7.3 U.S. quarts (6.9 l liters)(2.3CL w/ 5-speed manual)
7.2 U.S. quarts (6.8 liters) (2.3CL w/ 4-speed automatic)
Fuel Tank
17.2 U.S. gallons (65 liters)
Passenger Volume
84.7 cu ft
Cargo Volume (trunk)
12.0 cu ft
Total Volume
96.7 cu ft
FUEL ECONOMY
Factory Estimated Fuel Mileage, City/Highway*
3.0CL
20 / 28
2.3CL
25 / 31 (manual)
. 23 / 29 (automatic)
* California figures are the same.
EXTERIOR DIMENSIONS
Wheelbase
106.9 in (2715 mm)
Track, front
59.6 in (1515mm)
Track, rear
59.1 in (1500 mm)
Overall length
190.0 in (4827 mm)
Overall width
70.1 in (1780 mm)
Height*
54.7 in (1390 mm)
* measured at the Manufacturers Design Load Weight
Minimum Ground Clearance*
4.33 in (110 mm)
Curb Weight
3.0CL automatic
3215 lbs(1464 kg)
2.3CLmanual
3062 lbs(1390 kg)
2.3CLautomatic
3004 lbs(1365 kg)
Weight Distribution (% F/R)
3.0CL
64/36
2.3CL
63/37
INTERIOR DIMENSIONS
Front
Head Room
37.4 in
(951 mm)
Leg Room
42.9 in
(1090 mm)
Hip Room
51.6 in
(1310 mm)
Shoulder Room
54.4 in
(1383 mm)
Rear
Head Room
35.9 in
(913 mm)
Leg Room
31.0 in
(788 mm)
Hip Room
47.6 in
(1210 mm)
Shoulder Room
53.1 in
(1349 mm)
WARRANTIES
Vehicle
4-year/50,000-mile limited warranty
Outer Body Rust-Through
5-year/unlimited-mile limited warranty
Roadside Assistance (TLC)
4-year/50,000-miles
I tried a direct copy and paste but it wouldn't keep the formatting and everything wasn't very understandable so I just spent about the last 45 minutes making this look ledgible so please do post it, I don't want to have done this for nothing!!
here's the original link if you want to see it:
http://209.85.165.104/search?q=cache...ient=firefox-a
Engine Type
Horsepower, SAE net
Torque, SAE net
Redline
6300 rpm
Fuel Cutoff
6600 rpm (3.0CL)
6500 rpm (2.3CL)
Bore & Stroke
3.39 in x 3.39 in
3.39 in x 3.82 in
Displacement
Compression Ratio
Induction System
Valvetrain
Engine Block
Aluminum alloy
Cylinder Head
Emission Control
3-way catalyst
Ignition System
Alternator
12V, 100A (3.0CL)
12V, 80A (2.3CL)
Battery
12V, 72A (3.0CL)
12V, 52A (2.3CL)
Recommended Fuel
Unleaded regular
Body Type
Unit body
Front Suspension
Rear Suspension
Shock Absorbers
Stabilizer Bars
(3.0CL) Front
Diameter
Steering Type
Steering Ratio
17.4:1
3.0
Turning Diameter
39.04 ft (11.9 m)
Wheels
Tires
Braking System
Front Discs
Rear Discs
Total Swept Area
Parking Brake
POWERTRAIN
Type
Transmission
Ratios (:1)
3.0CL
4-speed automatic
2.3CL
5-speed manual
2.3CL
4-speed automatic
CAPACITIES
Crankcase
Cooling System
Fuel Tank
Passenger Volume
84.7 cu ft
12.0 cu ft
Total Volume
96.7 cu ft
FUEL ECONOMY
3.0CL
20 / 28
2.3CL
25 / 31 (manual)
EXTERIOR DIMENSIONS
Wheelbase
106.9 in (2715 mm)
Track, front
59.6 in (1515mm)
Track, rear
59.1 in (1500 mm)
Overall length
190.0 in (4827 mm)
Overall width
70.1 in (1780 mm)
Height*
54.7 in (1390 mm)
4.33 in (110 mm)
Curb Weight
3.0CL automatic
3215 lbs(1464 kg)
2.3CLmanual
3062 lbs(1390 kg)
2.3CLautomatic
3004 lbs(1365 kg)
3.0CL
64/36
2.3CL
63/37
INTERIOR DIMENSIONS
Front
Head Room
37.4 in
(951 mm)
Leg Room
42.9 in
(1090 mm)
Hip Room
51.6 in
(1310 mm)
Shoulder Room
54.4 in
(1383 mm)
Rear
Head Room
35.9 in
(913 mm)
Leg Room
31.0 in
(788 mm)
Hip Room
47.6 in
(1210 mm)
Shoulder Room
53.1 in
(1349 mm)
WARRANTIES
Vehicle
4-year/50,000-miles
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by PimpCL23
wait... i thought the Automatic was Heavier than the manual
Yeah!! Sorry the article was for the 1998 model. IDK if there was one for the 1997 model maybe there is ya'll are just gonna have to find it, I did my part. There's no satisfying ya'll is there, ungrateful bastards!!
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by DaInFaMMuS1
laugh all you want, ill take the 58 pound difference to never have to worry about my tranny!!!
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by TheBatmobile
OH SHIT!! Black you just totally jinxed yourself!! Watch in a week you'll be posting a thread about it!
contrarian in fashion
and we STILL faster! (than the 2.x autos that is)
My tranny's fine btw
i doubt u have as many miles as i do
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by suprachica79
wait, blackack- you have an auto? wtf lol
(Mid-Atlantic)
(Mid-Atlantic)
haha, true, sry blackack, I always thought you had a 2.2 for some reason lol
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by SwervinCL
Keep it up bouncy boy.
ahhh shit son....
its all good... i got some Illuminas to drop in! soo no more bouncy boy for me! LOL
Nah, I'm always in the debate about v6 vs 4banger. I have a 3.0 though
(Mid-Atlantic)
(Mid-Atlantic)
only if the v6 came in manual.... that would be frikkin awesome
Tell me about it
Nom Nom Nom Nom
When I first saw the CL when I bought it. I was like... Cool, maybe being an Acura, it will have a little bit bigger engine than the accord. I popped the hood and almost verbatim "Oh, its an F23"... The dealer was like "what" I said "Nothing, just thought the engine would be bigger....."
Besides, Your just jealous that we have 5 more hp than you and a nicer console....
Then no one would buy the 2.x.... I know I wouldnt have....
i was just fuckin around with the ">" thing!! just wanted to confuse people! i know i know... im an ass!
where do u think i got the "23" part in my name from
