Keyless Remote
Old May 14, 2002 | 08:05 AM
GoldieAlek's Avatar
Keyless Remote
I just order one of them remotes (cause i only had one)
do any of you guys know how to set it up ? or go to dealer is my only option to get it working ?
Old May 14, 2002 | 08:12 AM
STLUSMCH's Avatar
kept the beast
YOUR BEST BET IS TOO GO TO THE DEALER
Old May 14, 2002 | 08:27 AM
1StGenCL's Avatar
958 & 991
Nah dont go to the dealer unless you know them well and they will do it for free. Its really easy and just involves holding the remote up to the sensor and turning the ignition on and off as well as clicking the remote in a certain pattern. I have the directions around here somewhere. I'll try and find them
Old May 14, 2002 | 08:30 AM
GoldieAlek's Avatar
that would be sweet if you find them ! which sensor tho ?
Old May 14, 2002 | 08:35 AM
1StGenCL's Avatar
958 & 991
Here you go, thanks to an older post by Tw1112
"1. Turn the ignition switch on (II on the ignition)
2. W/in 1-4sec, push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit. (Just at the steering wheel is fine)
3. W/in 1-4sec, turn the ignition switch off
4. W/in 1-4sec, turn the ignition switch on(II)
5. W/in 1-4, push the transmitter lock or unlock button w/ the transmitter aimed at the receiver again.
6. W/in 1-4sec, turn the ign. switch off
7. W/in 4sec, turn the ignition switch On(II)
8. w/in 1-4sec, push the transmitter lock or unlock again.
9. w/in 4 sec, turn the ign off
10. w/in 4 sec, turn the ign ON
11. W/in 1-4, push the transmitter again
12. Confirm you can hear the sound of the door actuators. W/in 1-4sec, push the trans lock or unlock button again.
13. W/in 10sec, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch off, and pull out the key.
15. Confirm proper operation with the new codes
There you go! Sorry this is from the helms but my scanner is broken right now."
Worked great for me and the sensor is that little rectangular thing in the middle of your dash by the windshield
Old May 14, 2002 | 08:38 AM
GoldieAlek's Avatar
AWESOME ! thanks 1StGenCL !!!
Old May 14, 2002 | 08:40 AM
1StGenCL's Avatar
958 & 991
No problem. If it doesnt work the first time just try it again because it is easy to mess up but it def. will work, eventually.
Old May 14, 2002 | 01:08 PM
Blacura's Avatar
-iii-(
will the newer style keyless remotes work with our cars? will they be able to be programmed to our alarms? anyone know?
Old May 14, 2002 | 05:41 PM
Zoot's Avatar
__
I was just about to ask the same thing. My dad has a new CL and the keys are cool! I dunno if they will work though since they have something to do with the mem. seats.
Old May 14, 2002 | 09:07 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
In the future, the instructions are posted on my web page: Remote Instructions.
Old May 14, 2002 | 10:38 PM
1StGenCL's Avatar
958 & 991
The tl-s/cl-s remotes will not work with our cars according to jens (acura mechanic guy)
Old May 15, 2002 | 07:58 AM
GoldieAlek's Avatar
Thanks Rick i printed them out !
now i have more info that i need !!!
Old May 15, 2002 | 01:07 PM
Tripn's Avatar
Can someone also save this thread in "Extremely usefull topics" for future use.
Thank you
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
saturno_v
Sep 27, 2015 08:13 AM
