just installed fog lights, need help on the switch!!
Old Mar 2, 2003 | 09:38 PM
azn5ucka86's Avatar
though the bumper cutting was not pretty, the fogs were finally installed with piaa h3 yellow ion bulbs, thing is though is that i can't get the switch in, anyone know how to get it on? this is the fog light switch for the 1999 CL
Old Mar 2, 2003 | 10:42 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Take a small flat head screw driver, and pry out the plastic "knock out" plate to the right of your clock. Once you do this, the wires that you need to plug into the switch will be connected to the back of the "knock out" plate you just pried out. Take the connector and push it into your switch, then push the switch in where the plastic "knock out" plate used to be.
Old Mar 2, 2003 | 10:43 PM
azn5ucka86's Avatar
i tried prying it out, but i guess my screw driver isn't small enough?
Old Mar 2, 2003 | 10:48 PM
CLTECH's Avatar
Honda Technician
have you taken off the wood molding yet? Normally a lot easier to pop that switch out when the console is off. Could also be that your screw driver isn't slim enough. Try using a putty knife.
Old Mar 2, 2003 | 10:59 PM
You'll need a screwdriver the size used for glasses or watches.
You can also try using a straight pin (for sewing).
Good luck! You're sooooo close to being done!!!!
EDIT: Look closely, there may be a small notch to allow the blade of the screwdriver to fit in.
Old Mar 3, 2003 | 01:40 AM
azn5ucka86's Avatar
alright dust, yet again you've helped me through another mod install, haha, looks like next week will be the door sills, no problems there right?? i'll have pics of the fogs installed in another thread
Old Mar 3, 2003 | 08:53 AM
Cool!
I'm glad you got them working!
Door sills are pretty easy to install. The only issue is if you'll need to glue them or not. My double sided tape wouldn't keep them in place.
theinsvnity
Sep 10, 2015 10:22 PM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
