Just checking in...new member
Well, I thought I'd introduce myself here, as I just purchased a 1998 Acura CL 2.3 w/ manual transmission with 182k, in black. I paid too much, it needs work, and it's slower than the car it's replacing (93 Prelude VTEC), but none the less I am excited about it!
I'll start off with replacing the front brakes and rotors (warped), and fixing the exhaust leak (wherever that may be). I may need to rebuild/replace a caliper as one side is showing significantly more wear than the other. I think it will need a clutch too, because the engagement point seems high, but that is for another day.
Other than that, I have some cleaning and some cosmetic issues to address, but thats true when you buy any used car thats this old.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Congrats on the new CL, and welcome
Thanks for the greetings! I've already learned a little bit about this car from this site.
Brakes are from a 98-02 Accord, gauges are from a 94-97 Accord, and windows motors are from a 94-97 Accord (what, they had to pick the worst power windows they make? Ugh!)
What's everybody using for rotors? I am not looking for a slotted and dimpled EBC (like I have on the Prelude), but something that won't warp in 10k either. Suggestions? Cheap is good, very good, but not so cheap I am replacing them every couple of months.
My big issue, once I get the mechanicals taken care of is the interior. It's cloth. I wanted leather. Try finding a 98/99 CL with leather in black. Good luck! My guess is the cheapest way to switch is an eBay kit.
I guess I should let everybody know what my intentions are for the CL. It's a commuter, get me back and forth 26 miles each way, at least 5 days a week. With gas at $4+ a gallon, the 4cyl manual made the most sense. Plus its a Honda (Acura). On a similar note, I will have to take clients to lunch occasionally, so that's why I went with the CL.
Here's my immediate plans
Front brakes and rotors
Rear brakes and rotors (only if necessary)
Front caliper(s)
Fix exhaust leak (muffler?) - If a need a muffler, I am going as close to stock/quiet as I can get. Suggestions?
Down the road
Plus size wheels and tires (I drive on roads the make the moon look smooth, so that will factor into the decision)
Suspension - likely KYB's but a Tein kit is possible (right Marcus?)
Leather interior
Upgraded sound system (No subs, unless they take up zero space)
Well, now that you know more about me, my car, and my intentions than you ever wanted...I'll stop.
Thanks again!
Front caliper(s)
Down the road
Leather interior
Thanks again!
high gas prices are one of the reasons why i went 1st gen CL instead of 2nd gen, even though they were a little over $2/gal when i got the car. but i cant argue with 30mpg.
also, in my opinion it is much easier to find a CL with leather instead of cloth. i guess the last guy that i remember on here that had cloth hasnt been on in a long time (xxatthegatesxx). trust me though, in the summer you won't regret getting the cloth. black car+black leather=ouch.
Welcome to the board! let me know if your exhaust leak is in the rear exhaust section (axle back section) i have a stock rear exhaust section (muffler+stock pipe and flange) for sale in good condition, PM me if interested. others will help you achieve those mentioned goals aswell. good luck and get some pics up!
DJ MSR NRG!!
lol heyy i have cloth !
Your right...
"You also won't be able to use the private message system, edit your userprofile, or add photos to an album right away either. As soon as you have accrued 5 posts and have been a member for 15 days, you will be granted this ability."
Not much I can do about pics now is there?
Your right...
http://www.flickr.com/photos/cburnscrx/
the stock rotors won't warp after 10k..they wont warp after 50k lol.. they're massive and they use the crazy hub over rotor thing..hope you got a buddy with an arbor press or else you'll be paying 100+ dollars just to have your rotors taken off and put on
Unless I am mistaken, that only applies to the 97 CL, not the 98 and 99's. I could be wrong though.
For the record, they're already warped...unfortunately.
Your right...
PICTURES BELOW
If this doesn't work, just let me know and I'll email ParaSurfer the pics so he can post them (the pics are on my desktop at work).
