Found this 3.0 on KIJIJI today that was imported from Japan... never seen one like this before though...thought i would share with everyone and get everyones feelings on the cover.
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ176001541
2600lb CL
I'm a little confused why it says VTEC when the JDM J30A3's were IVTEC (I believe it was A3, but would have to verify it, havent talked about this particular engine in years).
Anyways, since they use different heads, I would ask myself if the manifold is even the same. That'd be my first question.
97BlackAckCL
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
close
- Join DateJan 2005
- LocationShitsBurgh
- Age44
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:4,694 Times in 3,233 Posts
I've always wanted this type of cover like the J32's, I actually looked into this swap, but like cocoa said, the IM is different
I like the way it looks! If i was going to keep my CL i would of maybe swapped this.
wow, interesting. is it a drop in swap or are we going to have to hack up wire harnesses just to start!
2600lb CL
Quote:
The jdm J30 was an engine I looked into before ever blowing my engine. I learned that the wiring on it would have been just a big of a pain in the butt as the CLS wiring. So that being said, it' far more beneficial (hp wise) going with paying for the pain of dealing with the wiring of the cls as opposed to the jdm j30 (I believe it put out 215hp). But, it might fit better/easier than the cls, although that's something someone would have to confirm on their own.Originally Posted by Mach30SiR
hmmm, comes with ecu as well
anyone else notice the coil packs? not running 87 in that sucker.
^ Yeah i think the AD said it was a complete setup...i wonder how much it really is though...
just called them $1200CAD. they have the coil pack one and another one with a distributor setup. both with trans/complete.
Ohhh no , this is no ordinary 3.0!
Sent from the Japan Gods.
One of these beasts installed!
2003 Accord Coupe V6
I did some research on this engine due to curiosity! Anyway this J30A engine above was used in the 2nd generation Honda Odyssey in Japan. The 1st gen Odyssey 95-98 RA5 did come equipped with the J30A1 from the 98-02 Accord V6 from the states with 200HP and a 4AT. The 2nd Gen Odyssey 99-03 used the JDM J30A in the RA8 and RA9 models equipped with a 210HP rating. RA8 was 2WD and Ra9 was 4wd(that was interesting to hear with 4WD and paired with the J30)! Another thing that was interesting is that the JDM J30a in the 2nd gen odyssey was paired with a 5AT with Honda S Matic(Tiptronic). I am still pissed at honda for not offereing a Honda S matic on the 03-07 Accord V6's, plus Honda doesn't even use Honda S matic on the 8th gen accord!! Only acuras and the honda fit get that treatment! WHY HONDA WHY!?
Anyway here is the website where I got this info,
http://en.wikipedia.org/wiki/Honda_Odyssey
i would guess this is the 210hp version and the distributor one is 200 like ours?
Yeah this one is 210-215HP.
Not bad...would make a fun little project...almost one of a kind swap on this site.
