intake humming
intake humming
I recently installed a SRI intake for my 3.0 and i hear a loud UFO noise (while throttle is at idle and under 1.5 K RPM. I can only assume that the pipe itself is vibrating to a harmonic resonance and makes the thing amplify the sound.
Otherwise, the little noise from the intake is resonating in the (resonator) and it is freaking loud.
In the upcoming days i will try to fix this problem and keep you guys posted.
(it also seems to resonate in my garage as well. I pulled it into my friend's garage overnight (after a few too many drinks) and it wasn't nearly as loud...)
I will try
Blocking the resonator (trumpet portion)
Removing the resonator
Modifying the intake.
I will try
With the paper plugging
the plugging helped a bit, quieted the thing down a little but it was still pretty darn loud. So I went on to step two the resonator removal.
(installed with the resonator removed.)
this was just as loud as before any modifications at all.
So i took it over to a friend who owns a speed shop for some advice. He removed the filter and put a towel across the intake. No Hum whatsoever. put the filter back on and there it is again.
i figured making a fin to go around the bend in the pipe would fix the vibrations... it went well and just about halved the decibels but there was still a hummmmmmm.
All I can think of now is to get a K&N with a 30 degree angle and lop off nearly half the bend and continue it with the filter. That would reduce the turbulence going around that corner.
Now that I think of it, there is a SLIGHT hum but now where near as loud as what I think yours sounds like. Looks like the same intake too. Looks pretty low tho. Sounds pretty good to me.
Ytse has the idea... I have been told i can be heard down the block... My UFO going on a probing run.
Update:
It was exactly what i thought. the harmonic resonance because of the length and shape of the tube made it so that it had reacted to the fundamental frequency of the air traveling through the filter.
this made it freaking loud!
i shaved the tube down about a half of an inch from both ends and the sound was reduced drastically.
I removed the bend completely like doubleshot suggested and it worked like a charm.
I am making a cold air box next i made a template as long as my intake was off and submitted it to a friend who will fab it up for free. It should be done today.
Just because im thorough... I borrowed the local college's decibel meter.
Horn (for reference): 108db
Stock intake: 73db
SRI Humming: 91db
Resonator with paper: 85db
No resonator 90db
Straight Pipe 75db
I couldn't get the fin tested before I had to give the meter back but i would guess it helped around 2-5 db
Those of you with 3.0s who haven't had this problem did you have a no-name filter or say a K&N?
Side note: Recommended spark plugs anyone?
Update:
Stock intake: 73db
SRI Humming: 91db
No resonator 90db
Straight Pipe 75db
I use a no name (BOMZ Racing) intake and air filter. I do have a K&N air filter tho. I still gotta try it on. But I have a slight hum (what you would expect with a aftermarket intake which is kinda the point) but nothing you can hear "down the block" as some of you say, or UFO, whatever that sounds like.
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
Take out the whole resonator
? lol. try the resognator thing.. how bout some
