Installing sub to stock deck??????
Old Oct 16, 2004 | 05:59 PM
tony408's Avatar
Well my sub is installed but it makes a loud humming sound when i turn off the radio/or engine. it gets pretty annoying sometime. anybody know why or how to get rid of it???
since i have a stock deck, i spiced up the rear speaker wires which then connects to a rca converter. i heard without the rca converter it makes this noise because of high frequency instead of low. But in my case, i have a converter but it still makes the humming. Any suggestion Please!!!!!!!
Old Oct 16, 2004 | 06:27 PM
JetBlackAcuraCl's Avatar
Promiscious Boy
recheck the switch you hooked the amp up to...to turn it on and off. also recheck ur ground...make sure its a reliable ground and that its not loose
Old Oct 16, 2004 | 09:07 PM
tony408's Avatar
the switch is ligit, i check twice and the ground was remounted to a solid place. it doesnt even move. my last resort is to buy a switch but its not an option that i want to head right now. any other suggestions ??
Old Oct 16, 2004 | 09:17 PM
Hobo's Avatar
Flap.
av forum?
grounds need to be to bare metal
Old Oct 16, 2004 | 11:08 PM
liloj's Avatar
i like orange juice
how is your amp turned on? where did you connect the RMT wire...if you amp is still on after the sound is off..it will do this.....just connect it to the RMT wire in the Bose amp or buy a switch
Old Oct 17, 2004 | 01:12 AM
tony408's Avatar
yeah probably the amp is still on after sounds is off. so where is the bose amp located, that sounds like a good idea LILOJ
Old Oct 17, 2004 | 04:22 AM
liloj's Avatar
i like orange juice
its near the jack in the trunk....a few blots and screws is all its secured by...and just find the RMT wire and tap into it....i forgot which one it is....but thats how mine is..ill check the wire color when i get home unless someone answers before them..i know theres a diagram that dustbuster has...but im to lazy to search right now
Old Oct 17, 2004 | 04:45 PM
acinteg10's Avatar
If you need needs to do that let me know I have them in my house sitting here and will sell them to you PM ME OK thanks.
Old Oct 17, 2004 | 05:41 PM
Acura2.3CL's Avatar
Mine did the same thing until I got an aftermarket deck. However, I do not have bose in my car so I dont know if that would affect it. I suggest as soon as you get the money buy an aftermarket deck. They sound so much better with the woofers!! Hope you get this taken care of, I know how much of a pain it is. If you dont get it fixed, just turn the gain down on your control before you turn the car off, that helped for me. Once again, hope it gets fixed!!
Old Oct 17, 2004 | 07:04 PM
acinteg10's Avatar
If your getting engine noise I feel sorry for you the only way you can avoid that with is a engine noise reducer. Good Luck!
Old Oct 17, 2004 | 08:05 PM
Hobo's Avatar
Flap.
there should never be an unreslovable ground problem, a ground loop isolator is a quick fix that may be helpful though
Old Oct 18, 2004 | 12:53 AM
tony408's Avatar
thanx for info guys
yeah this humming noise really gets annoying, especially when you have a 2002 acura cl. such a nice car and yet it has this minor but loud problem. yeah thanx liloj, i found the amp and sliced up the blue wire, assuming its the right one, and the results is close to perfect. the noise is reduce to a small, unnoticable noise. well i guess its better than nothing right. oh yeah, (hobo), my ground is connected to a metal frame in the trunk. ground might not be the problem.
james357
Feb 13, 2016 02:37 PM
Abe_Froman
Sep 16, 2015 01:27 PM
Dunnik
Sep 15, 2015 11:52 PM
