install cai questions??
I just installed my aem cai today to replace my aem short ram in my car. I have a few questions about it. When I had my short ram on, there was a "hissing" kind of sound at idle but with the CAI it sounds more like a resonant hummm. I cut my intake pipe near the about two inches away from the nipple sticking out because it was the only place that provided enough clearance for the bypass valve. I attatched the nipple to the hose that is connected to it when it was stock/short ram. I have two rubber tubes with a little foam thingie and this little plastic piece...Did I miss a step???
DAN
acuradan69@aol.com
DAN
acuradan69@aol.com
what about those 2 rubber hoses foam thingie and the plastic thingie included with the set. I have a felling i missed a step=0 WHats all this I hear about plugging lines, resonator control etc, I dont really understand it. If someone would explain it would be appreciated...
thanks
DAN
acuradan69@aol.com
thanks
DAN
acuradan69@aol.com
On the 2.2 theres a vac line attahed to the Air Intake Resonator. Thats the only vacuum line you need to plug unless youve removed the vaccum tank (about the size of a wallet, I left mine in)for that system too. All these vac lines are for the AIR and can just be cpped off now that youve gone with the CAI. The hissing is the air passing throughthe CAI at idle. You can increase or decrease by adjusting the idle screw on the throttle body(it will also affect your idle
BTW, I had several parts left including the filter thing. All the vacuum lines I disconnected off of the stock mountain of plastic I simply capped off.
Most of the dealing with the vacuum lines should have already been done with your short ram so as long as you connected the hose to the valve cover you should be in business.
Originally posted by acuradan69:
<STRONG>I just installed my aem cai today to replace my aem short ram in my car. I have a few questions about it. When I had my short ram on, there was a "hissing" kind of sound at idle but with the CAI it sounds more like a resonant hummm. I cut my intake pipe near the about two inches away from the nipple sticking out because it was the only place that provided enough clearance for the bypass valve. I attatched the nipple to the hose that is connected to it when it was stock/short ram. I have two rubber tubes with a little foam thingie and this little plastic piece...Did I miss a step???
DAN
acuradan69@aol.com</STRONG>
DAN
Skirmich
Sep 15, 2015 06:41 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
