indiglo wiring
Old Jul 9, 2001 | 03:36 AM
indopinoy's Avatar
very punny....
indiglo wiring
ive installed my indgilos once already, but they blew, i had them connected to the headlight.
where did yall connect yours. i was thinking about the parking light fuse in tha hood, or maybe the meter light fuse in tha interior..is there a better spot to do which is fairly easy to install? and wont fry?
Old Jul 9, 2001 | 01:53 PM
indopinoy's Avatar
very punny....
Old Jul 9, 2001 | 02:24 PM
rmstoico's Avatar
i like chicken
wire them to the dimmer switch on the dash. there are 2 red wires which you can run the positive into either one, and the black goes to the ground.
Old Jul 9, 2001 | 04:03 PM
1StGenCL's Avatar
958 & 991
I heard wiring them to the dimmer switch was really bad and would blow the dimmer and gauges out. I used my parking light wire. No problems and i have had them for a while
Old Jul 9, 2001 | 04:14 PM
revolver's Avatar
I just use the same power/ground that the radio uses.
It would be better if I could find a power that turns on and off with the lights though, because there's no power switch, but in the daytime you can't tell if their on if you dim them all the way down.
Where'd you guys mount your dimmer switch? I just kinda jammed mine in that slit under the steering wheel.
Old Jul 12, 2001 | 04:21 PM
rmstoico's Avatar
i like chicken
i wired the power and ground into the dimmer and they have been fine for 6 months. no problems
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
