idle probs
Old Apr 15, 2002 | 01:17 AM
clac225's Avatar
tlac356
idle probs
does anyones CL idle rough????sometimes mine gets down to 300rpms and want to stall out
what do you think???
Old Apr 15, 2002 | 01:32 AM
hornyleprechaun's Avatar
Bent = #1
nope...
CL'S
Old Apr 15, 2002 | 10:13 AM
99CL2.3's Avatar
No, mine idles perfectly. Check your injectors for flow, maybe?
Old Apr 15, 2002 | 12:10 PM
f0de's Avatar
Ham Sandwich
throttle position sensor
Old Apr 15, 2002 | 12:49 PM
clac225's Avatar
tlac356
Originally posted by hornyleprechaun
nope...
CL'S
thanks alot buddy
Old Apr 15, 2002 | 01:22 PM
StangDriver5650's Avatar
Make sure there aren't any obstructions in your air intake. Check for a clogged filter or any debris in the intake tube itself. I'm not sure how anything could get in but if the filter isn't clogged, check the intake tube. It sounds like you're either starving your engine of air or have a timing problem.
Old Apr 15, 2002 | 04:01 PM
Blacura's Avatar
-iii-(
mine does that all the time, i gotta keep my foot on the gas so the car doesn't stall out, maybe it's time for me to get a CAI
Old Apr 15, 2002 | 05:04 PM
clac225's Avatar
tlac356
ye but I think it started doing that after I got the cai, I thought the air/fuel ratio was lean, so I asked my friend (with a built turbo SI) if I should get the AFC, and he laughed at me....then I punched him
Old Apr 15, 2002 | 05:16 PM
Chinisimo's Avatar
Check the air intake tube. if you still have a rubber tube, it may have a crack in it. this happened to me w/ my old mazda mx-6. i electrical taped it until i have like 40 bucks to replace it. the good ol' college days
Old Apr 15, 2002 | 05:29 PM
clac225's Avatar
tlac356
Nah, its an AEM cai, man Im still in the ol' college days
Old Apr 15, 2002 | 11:43 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
Try replacing your PCV valve. its only like $2.79 and it could't hurt anyway! A dirty one will make your idle all fuked up.
Old Apr 16, 2002 | 01:52 AM
haiduc's Avatar
Moderator Alumnus
that could be a cause of it..... clogged filter/intake... f-ed up pcv valve.....
the most likely cause might be what f0de said.... it might be the throttle position sensor that is caught on somehting or just malfunctioning....
a new one costs a preety penny last time i heard.
are you sure that your throttle cable is not getting caught on anyhting for some reason?
Old Apr 16, 2002 | 10:51 AM
clac225's Avatar
tlac356
I will sit there and it will idle fine at 500rpm, but as the car heats up or cools down it will start to creep down to 400 then 300 and the dash and the rest of the car will shake
Old Apr 16, 2002 | 11:19 AM
Bent = #1
Originally posted by clac225
thanks alot buddy
Hey all I did was answer your question...thats all the input I had on your problem, I didn't want to pull some smartass comment out of my ass...
CL'S
Old Apr 16, 2002 | 02:24 PM
clac225's Avatar
tlac356
ye ye ye.....
Old Apr 16, 2002 | 03:02 PM
Bent = #1
I'm just playin with ya man...I don't wanna cause any tension between us...My car doesn't idle rough at all like you described..
CL'S
Old Apr 16, 2002 | 05:35 PM
skyline's Avatar
Funny how i WAs going to post a topic on this issue AGAIN ! my car has been funny lately ! As i have posted before, the stalling or low rpm problem only occur when i start the engine, it shocks really bad when rpm is low. Now I think about it, i have no cleaned my K&N filter since i bought the filter!! its been what? 20k miles? I tihnk thats why.
Btw, where is the pcv valve?
and how can you check if your throttle position sensor is not working properly? Bring it to dealer?
Thanx
Old Apr 16, 2002 | 05:40 PM
99CL2.3's Avatar
If you can find out the voltage range from idle to full throttle for a properly functioning TPS, then you can take a voltmeter to the sensor and test idle and full throttle. Unless you're under warranty still, then just take it to the dealer.
BTW, I'm still looking for connections in Vancouver for treez. I'm headed up that way in June if you could hook a brother up
Old Apr 16, 2002 | 05:43 PM
99CL2.3's Avatar
And yes, you should definitely clean your filter. I'm not sure, but I think they recommend "recharging" it after like 10k?
Don't know exactly where the PCV is on our car, but it's a plastic thing that should lead out somewhere from the crankcase and looks like a hose connector.
Old Apr 17, 2002 | 12:35 AM
clac225's Avatar
tlac356
he man, post that shit on the black market forum
Old Apr 17, 2002 | 12:56 AM
moforose3.0's Avatar
What can I get ya?
Chances are there is nothing in the filter. I would just go get a tuneup.
DerrickW
Nov 15, 2015 05:52 PM
012TL-GLM
Oct 5, 2015 06:32 AM
Skirmich
Oct 1, 2015 12:59 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
