Idle Problem
Old Jan 5, 2005 | 02:45 PM
IEILAINI's Avatar
Idle Problem
I have a 1997 3.0 with a little problem. Not always but at times when i start the car it idles rough and almost stalls, it actually stalls sometimes. I hold the gas for a few seconds and everything goes back to normal, and usually happens on a warm start.
Old Jan 17, 2005 | 12:49 AM
vkilmor's Avatar
i got the same problem not sure what it is, but i've heard it may be the spark plugs & come to think of it i've had this problem when i used bosch plugs so imma run a test and change them to ngk's.
Old Jan 17, 2005 | 12:51 AM
vkilmor's Avatar
@ idle i run @ 800 rpms when it gets rough it runs @ like 400 then i give it gas and it runs @ normal
Old Jan 17, 2005 | 08:47 AM
LCARUCA 97's Avatar
Trailblazer = SUCK
check your plugs/rotor/wires/coil/icm. more then likely one of those. all can be done by driving up to autozone or whatever place you have in your area.
Old Jan 17, 2005 | 08:30 PM
Mitchel's Avatar
broke ass fawker
same here every once in a while my car will start and run really ruff. sometimes it stalls and i have to give it gas untill it runs normal. my car has even been worked on for this problem and never could get it fixed.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
TL14
Sep 24, 2015 04:37 PM
