Idle to low
Old Sep 27, 2005 | 12:03 AM
RedX's Avatar
97 Acura 2.2CL 160k miles
Idle to low
Is there a way I can adjust the idle to 2000 rpm?
Old Sep 27, 2005 | 01:57 AM
wilp99's Avatar
yes but thats bout 1200 rpm too high. why do you want it that ghig?
Old Sep 27, 2005 | 06:28 AM
SupraManAG's Avatar
One custom CL
You can adjust your idle cable to whatever rpm your little heart desires but 2000 is TOO high. 800-1300 is accepted. At least to me.
Old Sep 27, 2005 | 01:40 PM
wilp99's Avatar
theres an idle adjustment screw unter the throttle plate. only takes a turn ot two to make it that high.
Old Sep 27, 2005 | 05:54 PM
$peed])emon's Avatar
Si says "shut the fuk up"
my normal idle speed is around 400 rpms in my 5spd......is that kinda low???
Old Sep 27, 2005 | 06:44 PM
Clman02's Avatar
h22
yeah sounds a little low....if you want to waste alot of gas you can raise it to 2000
Old Sep 27, 2005 | 06:47 PM
Smalls's Avatar
Insert Sarcasm Here
my idle kinda pulses when I start the car for a second, then evens out about 800. Does this happen to anyone else?
Old Sep 27, 2005 | 06:48 PM
Hobo's Avatar
Flap.
before you move an idle adjustment screw try cleaning air filter, throttle body, and carbon deposits
Old Sep 27, 2005 | 07:30 PM
devildogUSMC's Avatar
hey my car is doing the same thing. when i start it the idle is low then i let it warm up a bit and it evens out WTF!!!!!
Old Sep 27, 2005 | 08:40 PM
Mulk's Avatar
The new ride
im gonna go make my idle 3800 RPM so i can VTEC all the time!
Old Sep 27, 2005 | 09:21 PM
MiniDevil's Avatar
Would the brakes physically be able to stop the vehicle?
Old Sep 28, 2005 | 08:29 PM
732xghost's Avatar
does your idle raise and drop or does it stay at a constant 400???
Old Sep 28, 2005 | 08:52 PM
ajtcl's Avatar
Peace, Love & Acura
Man, I'm glad he has a 5sp... if you did that to a 3.0, the transmission would fall out when you put it in gear. The brakes would hold it, but you would feel the frame stretching...
Leave it around 800 at idle... WTF would you want to do that anyway.... it wouldn't sound cool... it wouldn't be cool. If your idleing at 400, you should just turn the idle set screw about 1/8th turn clockwise... that would prolly do it. My civic had a problem that was related to the seasons... naturaly aspirated carborator... when the weather got cold, had to turn it up... But I don't think you are suffering the same issue... iacv or maps sensor may be the issue. Ohm the parts if the idle set screw doesn't help you.
Good luck.
Old Sep 29, 2005 | 01:23 AM
well the pointer stays just below the first short line on the speedo....so i guess that is the 400 mark....
Old Sep 29, 2005 | 01:31 AM
http://www.acura-cl.com/forums/showthread.php?t=172353
in step 4 of that pic is exactly where my rpm is at...is it supposed to be there?
Old Sep 29, 2005 | 06:57 PM
RedX's Avatar
ok maybe 2000 is to much, I wanted to raise it because it idles so low that it wants to stall.
Old Sep 29, 2005 | 10:27 PM
wilp99's Avatar
then you have a problem somewhere.. maybee a vaccum leak or you just need a tune up.
Old Sep 29, 2005 | 10:40 PM
who was that response for?? me?
Old Sep 29, 2005 | 10:45 PM
wilp99's Avatar
naw man redx..
08KBP_VA
Oct 22, 2019 01:55 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Rcelestino93
Sep 23, 2015 10:01 PM
