IAC for 2.2?
Old Jun 17, 2006 | 09:06 PM
AznX TL's Avatar
where is....
IAC for 2.2?
can some post pics on how to take out IAC for 2.2? i need to clean mine really really bad
Old Jun 17, 2006 | 09:10 PM
AznX TL's Avatar
where is....
starting at intake manifold please!
Old Jun 17, 2006 | 09:46 PM
Mach30SiR's Avatar
Bagel Bomber
same place as 3.0, under the throttle body.
Old Jun 17, 2006 | 11:08 PM
AznX TL's Avatar
where is....
http://www.acura-cl.com/forums/showt...+Control+clean
same basic concept? unconnect tb, take out iac, put in new iac, replace tb gasket?
Old Jun 18, 2006 | 04:19 AM
Mach30SiR's Avatar
Bagel Bomber
yes
Old Jun 18, 2006 | 12:00 PM
Blenz's Avatar
Give us a DIY if you're gonna take on this project. It'd be appreciated
Old Jun 18, 2006 | 01:51 PM
Mach30SiR's Avatar
Bagel Bomber
why? is there something wrong with everyones?
Old Jun 18, 2006 | 03:45 PM
ingsoc747's Avatar
i think most people get excess carbon buildup... it is a flaw in the design of the car, i wish they would do a recall on it instead of only cover the 97's / up to 80k / 7 years or whatever bullshit they pulled
Old Jun 18, 2006 | 04:07 PM
SupraManAG's Avatar
One custom CL
No. It is not located at the same place. It is located on the same body but different location. The IAC on the 2.2/2.3 is located behind the manifold. Its held in place by 2 10mm bolts. Once those are removed you should remove the coolant hoses connected to it. Should come out then. Use a throttle body cleaner spray to clean it out.
At first the car WILL act up. Once the valve and ECU readjust everything will be ok.
Do not ask me for pics. I do not have them.
I wouldnt replace the IAC and if you are planning on taking out the throttle body then yes you might need a new gasket. You can also do with the same one. They are durable enough to last a long time. Be careful removing it though. Dont break it if you are planning on reusing it.
Old Jun 18, 2006 | 06:08 PM
Mach30SiR's Avatar
Bagel Bomber
Sounds strangely like the EGR problem your describing.
Old Jun 18, 2006 | 06:59 PM
ingsoc747's Avatar
haha i think you're right... got my acronyms confused
Old Jun 18, 2006 | 07:27 PM
Mach30SiR's Avatar
Bagel Bomber
word
Old Jun 19, 2006 | 09:07 AM
732xghost's Avatar
yea defenitly dont waste your money replacing it. i had mine de-clogged and it hasnt acted up since. thanks to supraman
Old Jun 19, 2006 | 09:18 AM
AznX TL's Avatar
where is....
idk if mine is clogged or broken because i have to refill the coolant everyday if i want to drive the cl, and even then im overheating like a mother, it stalls constantly and doesnt want to start
Old Jun 19, 2006 | 11:09 AM
732xghost's Avatar
damn, well then that might be more than just a clogged IAC. did the person before you honestly take car of your car. it seems like your having alot of issues with your car.
Old Jun 19, 2006 | 11:25 AM
SupraManAG's Avatar
One custom CL
if u have overheated more then once then your engine is shot
dont bother declogging anything
the IAC valve wont do anything to that extent
Old Jun 19, 2006 | 11:29 AM
AznX TL's Avatar
where is....
well the temp gauge goes past half way after 10mins of driving
Acura97Cl
Feb 6, 2003 08:01 PM
turbotk
Dec 1, 2002 01:48 AM
turbotk
Nov 23, 2002 12:42 AM
atm_ent
May 8, 2002 04:42 PM
