I just installed rain sensing wipers.
It's called raintracker and it works pretty good. I would have done a write-up, but It would've taken too long. Now I kinda wish I did, but is anyone even interested in this mod? Has anyone even heard of this mod? Overall I'm satisfied, but once in a while it'll stop with the wipers slightly up.
Originally Posted by cl_jay
wow i had never heard of this mod....so when it senses rain, the wipers start?
how much did they cost?
was it difficult to install?
It was $130 and was quite easly to install. I want to go back and clean up the wiring a bit now that I know how to do it.
All you do is wire up a few wires to the wires coming out of the wiper control arm thing. The only wire you cut is the "slow" wire. The rest are just tapped in. And there's only one diode to istall. Then you remove the visors, rear view mirror, and the side interior panel. I was suprised that once I remove the side panel, the wire just dropped right beside the dash for a clean install. Mount the sensor below the tinted strip on the window and put everything back together. Oh, then you install the button. I'll take pictures of the sensor now. For some reason it took a long time, but it wasn't difficult at all.
Originally Posted by Chinisimo
cool! i have a manual rain sensing wipers though!
Here's the sensor. I'm going to by a thing to cover up the wire and make it flush with the windsheild to give it a factory look.
Here's the button. It was supposed to sit rotated 90 degrees, but it wouldn't stay cause of the way I drilled the hole. Now it overlaps the dimmer button. I'm going to fix this later.
Pictures of the sensor outside.
Originally Posted by sumdumguy
Nice. That just works off the low speed right?
Klepto: I could've done a write-up with pictures, but I don't think I can do it now. It wouldn't make sense without the pictures. Now I regret not doing it, I just wanted to finish faster.
Originally Posted by azian21485
just curious does it change speeds as the rain gets harder or you go faster or anything?
Originally Posted by r0dxx
What's the point? I dont get it, when it rains cant you just turn them on?
true, hehe dont think i was raggin on you, i was jus curious.
its like one of those things when someone is sitting in your car and there like hahaha and it makes you feel good.
CheeseyPoofs McNut
10-11-2015 11:25 AM
