how to remove alternator pulley?
the maual says to use a 10mm box wrench and a 22mm box wrench..i dont understand how the hell this would work...has anyone else done this? if so how? thanks
if i were you i would take off the alternator to take off the pulley, also make sure when you install if you are a aftermarket pulley make sure you use a tourque bar to make sure you get teh right tourque cause too much could be bad and cause the pulley to get caught up
Jul 16, 2017 07:33 AM
dainmezron
Oct 16, 2015 06:56 PM
