How to install Ingalls Ball Joint Camber Kit!
Does anyone one know how to do that? Yes I've looked in the DIY section but that's not for the ball joint kit. Is it best just to install the ball joint kit and then pay some one to adjust my camber to spec or is that something you can do yourself? Also what about the rear camber will a mechanic actually do the rear washer trick and replace the stock bolts and add washers to it to adjust the camber in the rear?
yes and yes
Personally if you don't know what you're doing, just have the mechanic do both. Pressing ball joints in is a bitch, you also will want an alignment / camber adjustment after you get your height where you want it. But until you get there, you can just center the balljoints, it works pretty well. If you put the height where you want it, just get everything done at once
Actually I read the instructions that came with them and I got a pretty good understanding of how to install them. I think I could do that and then drive down somewhere and let them align it. ACtually maybe not cause the instructions said to torque the nut on the ball joint to 100ftlbs. but they wanted me to do it while the tire was on and the car was off the jack!?!? How is that even possible to get behind the wheel and do that?
you can def do it yourself, w/o serious tools. when they say torquing the nut to the ball joint to 100fr-lbs that doesnt mean you need a torque wrench. of course it would help, but not 100% necessary.
yeah but how do I access the nut with the wheel on?
Well I guess I can do it before I drop the suspension? Is that possible? With my ridiculous wheel gap I guess I'll have enough room before I drop but not after?
Jack the car up and take the wheel off
marcelft
Jul 10, 2018 06:17 PM
nuldabz
Sep 3, 2015 05:49 PM
