How do I remove the door panel?
Old Dec 23, 2002 | 03:53 PM
Blacura's Avatar
-iii-(
I tried searching and the search didnt work. Some kinda error or soemthin. So anyway I need to get my door panel off to fix my window. I unscrewed every screw i could see and i cant get it off, i dont wanna break anything by pulling.
thanks in advance
Old Dec 23, 2002 | 11:26 PM
SumkidwithaCL's Avatar
Turn Signals are good!
not covered under warranty huh??
pop the sail panel off... just pull it off... the handle "cup" has one philips screw in it... then it slides forward and can be disconnected... on the passenger door, there is a philips screw behind that that has to be removed... it also helps to take the handle and lock assembly off the door frame... there are screws in the armrest/door pull... they can be found under little "caps"... the door panel should then just pop off the door... once its popped loose, it slides up and off the door... its actually pretty easy.
Old Dec 24, 2002 | 01:55 AM
Blacura's Avatar
-iii-(
thanks jared, even if it's under warranty there's a 75 dollar deductible plus they'd take forever cause it's xmas...
sail panel is on the inside by the mirror? i took that off...
took the screw outta the thing behind the door handle...
took the screws (2) outta the armrest...
do i have to take the window button assembly off?
also where are the retaining clips and can i get them off with a flat screwdriver?
Old Dec 24, 2002 | 03:24 AM
klepto's Avatar
you have to disconnect all the wire plugs, for your alarm led, your door light, your door locks, and your power windows. The clips are at the bottom and can be "popped" off
Old Dec 29, 2002 | 05:12 PM
dwdrums's Avatar
hehe - my focus windows work! hehehe jk bro. hope it gets fixed easily. happy new year
Jason
Old Dec 30, 2002 | 10:59 AM
NotoriousCL's Avatar
Femme Fatale
Putting the panel back on is the hard part....
Old Dec 30, 2002 | 01:32 PM
Blacura's Avatar
-iii-(
hah jason, thanks bro. I'm gettin it fixed tomorrow.
Notorious, I figured i'd fuck somethin up so i'm gonna have a shop do it. Where in PA you at?
Old Dec 30, 2002 | 02:16 PM
aaron1017's Avatar
I spent a whole damnday trying to get my door panels back on because of the 6 1/2 speakers i put in, what a bitch. Who ever invented door panels is going to hell.
Old Dec 30, 2002 | 06:59 PM
Femme Fatale
Blacura - Hazleton, PA
Old Dec 31, 2002 | 02:25 PM
Blacura's Avatar
-iii-(
notorious, is that out by Reading?
Old Dec 31, 2002 | 04:04 PM
Femme Fatale
Blacura - about 1 hr 45 mins away from Reading
Old Jan 1, 2003 | 07:24 PM
MistaE13A's Avatar
aaron1017:
you dont have to take the door panels off to replace the 6-1/2" speakers. the grill on the door panel pops right off. after you take it off, you can take out all the screws holding the speaker in except for 1. to get the one, you cut a little bit of the door panel (make sure u dont cut above the grill or you can see it). then you take out one screw and u can do it without removing the door panel. takes no time at all
Old Jan 2, 2003 | 01:51 AM
Blacura's Avatar
-iii-(
buncha philly area peeps in this thread
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
CadiGTi
Sep 14, 2015 06:37 PM
04tler
Sep 10, 2015 01:13 PM
