How to calculate offset
Old Nov 1, 2006 | 09:13 PM
Mr. Pickles's Avatar
This isn't making sense to me with the conversion. Sorry, I'm a nOOb at this. I'm looking at rims that state 17x7, backspace 5.5. According to the chart in the nOOb thread, I'd be looking for 40-45mm offset for 215-45/17 tires, which threw me for a loop. I tried using this site:
http://www.rsracing.com/tech-wheel.html#backspace
But that confused me. Can somebody please chime in with a yay or nay on these rims for my 97 2.2? I think I'm missing something in the calculation. The rims claim to fit an Accord. Thanks!
Old Nov 1, 2006 | 09:42 PM
agranado's Avatar
how handsome I am
those numbers sound about right for that size wheel. Dont know what's so confusing.
Old Nov 1, 2006 | 11:07 PM
Honestly, what is confusing to me is, yes it should fit, or no it won't. I've got all the #'s, I just don't know what to do with the stats, what to convert or consider. Sorry again, this isn't really my realm. This is my wife's daily driver, and while I had a sick lowered Prelude back in the day, this really isn't my specialty. I drive a Nissan Pathfinder on 6" lift rolling mud tires, and big tires and lift have been my realm for the last many years.
That being said, what do you guys think?
Oh, and the offset figures I stated where what I read off the chart in the nOOb post. I don't know how to read the stats on these rims as far as to figure out if they fall within those specs for offset, etc. With the numbers I've given, would anybody be able to give some advice on if it should work, or where I'm wrong and what I should be looking for in the future. I'd like to end with roughly the rim size and tire size stated above, and am looking for help on getting there. Thanks again.
Old Nov 1, 2006 | 11:23 PM
sixfifty's Avatar
I
while we're on the subject, what offset are our stockers?
im low now and my wheels sit way the hell inside my wheel well, looks ugly as hell, what offset rims should i go for to get the flush look?
Old Nov 1, 2006 | 11:34 PM
lnsyone's Avatar
CL 4 LYFE
For a 7" or 8" wide wheel, +40-45 offset is safe. If you go with the 7, you should run a skinnier tire like a 205/40.
Old Nov 1, 2006 | 11:46 PM
lnsyone's Avatar
CL 4 LYFE
For a flush look like this, I'd say go with a lower offset prolly in the +20 range or lower; or a wider wheel like an 8.5".
If you want to run a flush wheel fitment while being slammed, you'll need to work your fenders and run skinnier tires.
The more wider or the lower the offset you go, you will run into problems. Best bet if you don't want to deal with problems, don't attempt it. If you love the look and don't mind the adventure, then persue it. You just need to be precise when calculating offset and wheel clearance.
Old Nov 2, 2006 | 12:21 AM
Thanks for input. So with the 7 as I stated, would this translate to a wheel pushed farther out? I have stock 16" with 205/55 and there appears to be plenty of room. With relatively similar width and diameter, would these rims go out farther then? Would I be looking at rubbing and stuff?
I'm looking for a wider tire/rim. I've got Michelin Pilot MXV4 on the car (bought it with them) and although they claim to be quiet and good handling, they are absolutely far from it. Loud, hard, and slick even on dry sticky asphalt. I'll probably be going either with Kumho's (cheap) or if I'm feeling rich Goodyear F1's, but I want some sticky (and probably wider) rubber.
Thanks again!
Old Nov 2, 2006 | 12:39 AM
lnsyone's Avatar
CL 4 LYFE
Thanks again!
Naw dude, 17x7" wheel is safe to run. Stock I believe is 16x6 or 6.5". A very common fitment would be 17x7 or 18x8 for example. You'll only need to worry about clearance if
1) You're lowered more than 3"
2) Running a wheel wider than 8.5"
3) Running a "low" offset like +30 or lower
etc.
Kumho's are great for the price. Even Federal's. I'd say stick to the common fitment; get a tire with good dry and wet traction and etc; and don't worry about going wider (especially if you're concerned about clearance).
Old Nov 2, 2006 | 12:48 AM
sixfifty's Avatar
I
what offset were you running on the white one?
like.. 35?
Old Nov 2, 2006 | 12:54 AM
lnsyone's Avatar
CL 4 LYFE
the ray's i was runnin before was a 7.5" +30 205/40/17.
both front and rear had some space to go wider but i was "pushing it" with that fitment at the ride height i was at (aka slammed). the only modifications i did was to the fronts only, which was flattening the fender lip; and removing the fender liner (cuz they served me no purpose).
Old Nov 2, 2006 | 12:57 AM
etc.
Cool, that basic part is what I was after. I didn't think a minor change in size would matter, just wanted be sure before I bought them. Yes, things will be stock height on only 7" and higher offset. Alllllright.
Old Nov 2, 2006 | 01:02 AM
lnsyone's Avatar
CL 4 LYFE
Should be all good for you
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
spoiler900
Oct 10, 2015 06:48 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
bailey24
Aug 31, 2015 05:38 PM
