Honda ATF
Honda ATF
Where can I get it? Do I have to go to the dealer, or do you guys know of a website where I can buy it?
Also, I was wanting to use some Seafoam or Lucas trans. addative. Should I mix it in before I change the fluid, or should i add some to the new stuff and just leave it in there untill my next change.
I always go to the dealership, my friend who manages an oil change chain tells me he can't get it from honda and makes me go there. As for the seafoam, you're supposed to use it then change oil right afterwards, u don't want that stuff chilling in your crankcase
Originally Posted by STL+3.0CL
Well actuallly I was refering to the transmission seafoam, but I assume its the same for that as well. Should I add a little bit and drive it for a day before I get it changed?
From their website
For Use in Automatic Transmissions
- With transmission at operating temperature, check the fluid level. Add 1/2 to 1 pint SEA FOAM TRANS TUNE to the transmission fluid. This normally will not overfill the fluid level, however, the fluid level should never exceed the manufacturers recommended level.
- For best results use 1/2 to 1 pint SEA FOAM TRANS TUNE in the transmission fluid prior to a transmission flush or fluid and filter change. Drive at least five miles shifting into all gears. If you are not able to drive the vehicle, shift into all gears for about 3 minutes with the brake or parking brake applied. This will allow SEA FOAM TRANS TUNE to clean transmission valves and parts in each area. When additional cleaning is necessary add 1/2 pint of SEA FOAM TRANS TUNE to the transmission fluid and change the transmission fluid on a regular service basis.
