high flow cat should buy or not
i know powercore makes a race cat but i want to know if any one has one and if it is worth the money or not i know u can't gut the cat cause of the o2 sensor
BUY OR NOT
BUY OR NOT
some have the hookup for the sensor but most dont. i head powercore is really a carsound cat (which is good) with the flages weled on so u can bolt it in. NOT SURE THOUGH. and racing cats are basically straight pipes so they would make the most diff, high flow still reduce pollution, but can flow faster than oem usually.
Originally posted by niedejb
Hmm.
The 2.2 has 125 wheel horsepower.
BTW drops dont make you faster.
Hmm.
Drops plant your tires to the floor better than stock so you get better traction=better acceleration and launch, but does not make your car faster?
I put a high flow CAT, but untill I put on headers I don't think it helped but with headers defenatly. I would go with a DOT approved free flow so you don't have trouble with inspections.
lol SooDARK calm down... this thread is from February 2003 about 9 months ago. So I guess having a high flow cat increases emissions output by a little and you could possibly fail smog but maybe not.
if they did... do you need to buy a new sensor? or is there already one there on the OEM cat you can remove and plug into the new cat?
Originally posted by q2slinger
I've got the random technology:
Accord 98-02 - 3.0L - 822008
Bolts right on (two O2 sensor bungs). Noticed a solid performance jump on the top end.
And anyone who asked about the o2 sensor, if you don't have it installed, get ready to see a check engine light.
Thanks!
Its a high flow cat that is supposed to be street legal.
The cat increases the exhaust noise.
I picked mine up for $220 from:
http://www.lightningmotorsports.com/...technology.htm
Def. worth it if you have headers and exhaust.
