HID info
HID info
yes another hid thread, lol
ok im looking into getting high and low beams hid is there any suggestions guys? thanks... also the ballast has to be hella or an equalivilant... and is this wut they call bi-xenon?
for hids, just stick with getting a set for your low beams, its just stupid to be dropping $300 on high beams...bi-xenon means that the low beam is dual filmaent so it works as your high beam as well i think. Some good ballasts are hella and philips, some good bulbs are osram and philips
bi-xenon is a projector for the most part but you can get bixenon h4s i wanna say, unfortunatly our car does not use an h4 Good call on the hella and you may want to look into the phillips unitron kit Good luck
IT CAN USE H$
CUSTOMIZE IT BABY!!!!
bixenon is a type of projector, it is not a dual filament bulb, when you do your high beams with a rs6 bixenon, hella bixenon or a bosch, the shield for the projector lowers and opens up to reveal more light, the projector is already bright enough without the high beam but once lowers it reveals more of the bowl, the bixenon is activated by a silinoid which lowers the plate andyou get your high beam and low in one, but most people have had troubles with teh bixenon going out meaning the silinoid goes bad or the plate get stuck in place and you are on permanent highs, ask VXCL about this one
here is a pic of a bixenon from a BMW 3 Series
The silinoid up close
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
