Hesitation starting
A-CL Member
Hesitation starting
My 98 3.0 had a heck of a time starting after I parked it at a store for about 15 mins.
It would start every time but would die right away.
After about 5 mins and a few tries, I was able to start it, hit the gas and keep the engine running, rough at first and then it was okay. the gas tank was less than 1/4 full.
This has happened twice. I have heard of some thing along the lines of a gas vapor lock.
Any ideas are greatly appreciated.
Originally posted by Hobo
well our cars just dont start as well with less gas in em..
so fill up sooner
so fill up sooner
when the gas is low, it doesn't start up as easily. i had to hold the key on for a couple of extra seconds.
but if it happens even if you have lots of gas, it might be an ignition problem
ok, this issue has come up quite a few times and the answer is this:
The reason for this crap when the gas is low is because of the bad design of the fuel pump on our cars. Something about how it is setup causes difficulty getting fuel to the engine when there is 1/4 tank or less. I dont know specifics but just about everyone i know has the same problem.
You been edumacated
You been edumacated
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Gimmie my points Biatch!
You been edumacated
You been edumacated
at lower levels the tank doesent have alot of pressure. could be the fuel cap gasket isnt what it should be. i know that if u leave the cap off our cars for long the car will die.
2005 SSM/Ebony/5AT/NAV
Re: Hesitation starting
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
So about two weeks after the dealer visit, the original starter died at 130K miles. Replaced the starter at dealer and haven't had the problem since.
Our trusted family mechanic/retoration expert (40+ years experience, so/so knowledge on newer cars) who does all the routine maintenance thinks that the heat from the engine was somehow preventing/heating up the dying starter and causing the problem.
Solution - get ready to replace your starter as nothing else we did (including changing the fuel filter) helped.
Let me know if you have ?s. Good luck.
I am also pretty sure it wasn't due to low gas in the tank as it happened several times to me just after filling up.
Also, I hazard to guess that it is probably not related to vapor lock because if it was, it would've happened before I hit the 125K mark (never did as I was sometimes driving it in 100-110 degree weather without any issues), and it would've happened again over the last 2-3K miles since I got the starter fixed.
oh u had a unique problem then....
I think these guys are having the typical CL problem...
At low fuel, the car struggles to start, but indeed it does start...only when the needle hits the 1/4 mark and below.
After the fill up, it starts in less than a second....but now I start my car differently...after reading something on these forums, forgot where.
I let the computer start up everything until i hear a silent click, gotta listen for it (usually 3-5 seconds), then I start it....it was said that there could be a slight chance of it messing something up, but highly unlikely....i'm a paranoid person
But (I think) the problem he has is that the car does start, so to speak, but the engine runs very rough and feels like it is misfiring and won't hold idle unless you manually give it gas and hold it down for a minute or two. Even though one can't flood the carb (since there is none to flood), it feels like the engine is being bogged down or in older cars, like the carb has too much gas in it - in general, it won't run smoothly, like only some cylinders are firing and not in the right order. Very odd feeling.
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
