HELP.....zex install
Old Jul 13, 2002 | 08:33 AM
jasshopper's Avatar
Hey Radio Shack.....Relax
me and my bro are installing the zex nitrous.....we can't seem to find exactly where the fuel pressure regulator is........anybody?
thanks...
Old Jul 13, 2002 | 08:36 AM
jasshopper's Avatar
and also.....if anybody has Dustbuster's zex installation process handy.....i know he posted a guide on how to.......SEARCH isn't helping like i want it to...sorry for rehashing this stuff...
Old Jul 13, 2002 | 08:48 AM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Here
Its the part at the top that looks like this:
More info
regulator
Old Jul 13, 2002 | 11:13 AM
jasshopper's Avatar
suweet......that's what i'm lookin for...thanks
Old Jul 13, 2002 | 03:19 PM
dcsquirm88's Avatar
I see you have a venom 400 on your car. If your installing the zex kit on your car, then don't use the venom and the zex at the same time. Venom advances your timing which is bad when used with nitrous. Your timing should be retarded for use with nitrous. Good luck with the install its really easy. The hardest thing is probably splicing into the tps. If you get stuck on that let me know and I'll help you out. Bye.
Old Jul 13, 2002 | 08:50 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Welcome to the N2O Club!
What have you "killed" so far?
Like dcsquirm88 said, don't run N2O and the Venom 400 at the same time!
Old Jul 13, 2002 | 10:17 PM
backstb01_RENAMED's Avatar
is there any chance of blowing the motor with this zex kit? or does it come with all the necessary things to make this kit a safe addition to a v-6 cl.
Old Jul 14, 2002 | 02:24 PM
jasshopper's Avatar
i gots the accessory wire hooked to an alternate aftermarket wire instead of one under the dash. Me and my bro seemed to have the uncanny ability to pick out all the relay wires under the dash. Where did all you N2O addicts splice the accessory wire? BTW....can't hit the go-go juice until Monday......Austin doesn't have a performance shop open that will fill a bottle on the weekend...
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
