Help with wiring
Old Apr 11, 2014 | 08:54 PM
jare86cmp's Avatar
5th Gear
Help with wiring
I removed my center console today to do some maintenance work and saw that there is a plug connected to nothing next to the clock. well i was wondering what those cables were? are they the basic power, ground, ignition ? i believe there are four. im asking because i want to add accent lights to the car but would like to add a switch in that location and that makes its alot easier .. wont need to cut into the lighter cable.. PLEASE IF anyone has done anything with those wires .. be kind enough to inform me
Old Apr 12, 2014 | 02:15 PM
SupraManAG's Avatar
One custom CL
you need to look at wiring diagrams and learn to read them. only then you can do what you want to do
Old Apr 13, 2014 | 07:44 PM
bRunCL's Avatar
Hard to say for sure without pics or knowing 97 vs. 98-99 but if you have a 98-99 there will be a female connector behind the blank knockout plate opposite the hazzard switch. That is part of the prewiring for the factory fog lights.
Old Apr 14, 2014 | 09:09 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Yep, it's most likely the wiring for the stock fogs
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
