HELP!! problem with shift lock
Old May 8, 2002 | 01:01 PM
bzboy's Avatar
"Dats da shiznit!!!!!!!!"
I have a 97 2.2 CL. I'm starting to have problems with my shift lock button on my shifter. It is an automatic. There are times when i cant press the button to change from "park" to "reverse, drive, etc." What i end up having to do is sticking my key into that slot just right of the shifter. Other times it works fine. Anyone know why this is happening and what i can do to fix it??? Thanks a lot!!
Old May 8, 2002 | 04:12 PM
Acura Sensei's Avatar
all stocker
Re: HELP!! problem with shift lock
this may just be related.....
something similar happened to me on another vehicle.
*cough*nissan*cough*
the Brake Interlock was damaged... thus preventing me
from shifting out of park.
also, are you parked on an incline? that adds more weight
on the brake interlock as well.
good luck... and don't force anything!
i learned the hard way.
Old May 9, 2002 | 08:58 PM
bzboy's Avatar
Thanks for the reply. Anybody else got any ideas???
p.s. yeah this was a cheap way of getting my subject to the top
Old Oct 23, 2005 | 06:46 PM
yossi's Avatar
im having the same issues
Old Oct 23, 2005 | 07:50 PM
hybridnrg's Avatar
...is now Carbon Fiber'd
did you change the shifter? because when i changed mine, you have to make sure you dont push it down to far, or have it too far up, otherwise you are going to have problems putting into gear.
Old Oct 27, 2005 | 06:17 PM
yossi's Avatar
nope, original shifter, any ideas?
Old Oct 27, 2005 | 07:54 PM
SupraManAG's Avatar
One custom CL
I have a auto shifter if anyone is interested.
Old Oct 27, 2005 | 09:24 PM
ajtcl's Avatar
Peace, Love & Acura
I have a similar problem. The issue is the lock solenoid. If it is dirty, you may need to remove the center console and clean the lock solenoid. When mine gets stuck, I re-engage the park brake and step on the gas a little. Then, I step on the brake again and it unlocks. You can also feather the brake peddle a little and you will hear the lock disengaging. Good luck.
Old Oct 28, 2005 | 02:24 PM
yossi's Avatar
hmmm, any photos/diagrams on how to remove the center console and access/clean the solenoid"?
mada51589
Jan 9, 2025 04:40 PM
tman570
Jun 11, 2019 07:56 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
obert
Dec 14, 2015 11:36 PM
Azonics
Sep 22, 2015 05:28 PM
