HELP: Power window not working-no weird noise.
OK, I did a search on the forum and found lots of problems with power windows but nothing quite like my problem.
Here's the rundown:
MY driver side window works fine and then 10 seconds later it won't roll back up from about 3/4 of the way down. It did not make any odd sound or anything, just quit working as if it is not getting power. AT this point my driver side window control would not roll down my driver side window but it would roll down my passenger side window and I could also roll down the passenger window from the passenger side control.I removed my door panel later tyhat day to try and get the window back up at least until I can get it fixed. I removed the door panel and unhooked all the various wires. Couldn't get the window back up btw but that is beside the point. I go to put the door panel back on and plug the wires back up. Once I get everything plugged back in I decide to try the control and see if maybe it works now. It did not and in addition my pasenger side window now will not roll down from either sides control. Any of you guys that can give me some insight would be much appreciated.
Here's the rundown:
xsilverhawkx
09-28-2015 06:51 PM
4drviper
09-23-2015 09:00 PM
