Help!! Electrical Problem
Old Mar 11, 2004 | 02:14 PM
VtecVsix's Avatar
Help guys, all of a sudden my radar with built-in voltage meter keep saying HI VOLTAGE, I looked in the manual and it said that if my battery is over 15.5 VOLTS it will keep saying that and the weird thing is that it will happen the most at 1500-1750 RPM.. I took it to the dealer and they said they couldn't do ANYTHING because I have aftermarket bulb and guage..... and I also heard a weird humming noise under the hood when this start happening. The dealer did however checked the alternator and said it was just a little weak... ANY ideas guys??? I am driving worry with the high voltage!!! Worry that it could damage other eletrical parts somewhere..... THANKS GUYS!!! PLEASE HELP!!!!
Old Mar 11, 2004 | 06:30 PM
wilp99's Avatar
ur battery will overcharge and could break. look at ur battery and feel the sides, if its bowed out at all u need to fix it asap. eather way i would just break down and replace the alternator, and maybee ur battery.....honestly, chances are nothing will happen cause batteries have an overboard dump, but if something does go wrong the battery could explode, so its best to fix it now.
Old Mar 13, 2004 | 01:22 AM
VtecVsix's Avatar
do you know how many AMP our alternator is?
I will replace it to see what happen...
thanks for your input!
Old Mar 13, 2004 | 01:23 AM
baka_t's Avatar
The movement has started
105amp stock 3.0
Old Mar 13, 2004 | 01:24 AM
VtecVsix's Avatar
ok got it 105AMP..
thanks
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
rboller
Sep 23, 2015 02:49 PM
