Help ASAP.
Old 06-15-2009 | 04:34 PM
CHRISdrivesACURA's Avatar
Help ASAP.
Ok, i was doing work to the ack today, when i took the head off, i realized from the time before i broke one of the upper bolts into the block should i still drive my car? btw, im not trying to show anyone what it looks like cause im not showing the car till its done. thats why its this picture.
Old 06-15-2009 | 04:54 PM
unlewser's Avatar
i dont understand why everyone on this forum is so
We end up getting threads like this.
https://acurazine.com/forums/1g-cl-1997-1999-56/ghetto-ninjas-epic-announcement-thread-731324/
That pic doesnt tell me much, but you should be able to drill out the broken part of the bolt...
Old 06-15-2009 | 04:59 PM
if you have ever taken the upper middle bolt out of the head, it is long bolt and holds it on, im sure i will lose compression, im not sure if i should just drill it out or not, i dont want to mess it up, and if i do drill it out should i re-thread it.
Old 06-15-2009 | 05:04 PM
Master Bill Flex's Avatar
I had the same situation before, so long as most of the bolts are tight (lightly tight with wrench, do not overtighten or it may break) there shouldnt be any issues. Make sure that the gasket isnt hissing from a loss of vacuum pressure. If everything seems normal, then it shouldnt be a problem. Drive it lightly until you get it fixed.
Old 06-15-2009 | 05:07 PM
YtseJammer's Avatar
Low and Slow
I drove around with a broken gasket seal for a couple months before I realized something was wrong, so I think you should be ok. I'd still get it fixed as soon as you can tho.
Old 06-15-2009 | 05:08 PM
The broken end that i had came out with a screwdriver. there was a little divet on the broken part that i could put a flat head in and turn it out. Try random tools to screw it out first before trying something expensive/hard.
Old 06-15-2009 | 05:45 PM
unlewser's Avatar
use something like this
http://www.sears.com/shc/s/p_10153_1...reverse+screws
Old 06-15-2009 | 07:51 PM
GhettoNinja06's Avatar
Skuuuurrrrrt!
https://acurazine.com/forums/showthread.php?t=731324
lmao! I was just about to post pics and a story to shut you guys up too but blackack closed it. Ohh wells, Thanks Chris!
Old 06-15-2009 | 08:32 PM
South Jersey CL's Avatar
well fred, make your own thread! that thread got us semi-excited.
thats one of the big reasons why i won't paint my valve cover, i'm afraid im gonna break something and fuck it up.
Old 06-15-2009 | 09:39 PM
Skuuuurrrrrt!
No way! Now that the thread is closed, I don't have to post anything.
It's a long story...
BTW, didn't something like this happen to Nate?
Old 06-16-2009 | 12:32 AM
Gnate's Avatar
Custom User Title
lol yes, same exact thing, i just had my mechanic do it, he even had a replacement screw on hand so I was golden! :gheylaugh
Old 06-16-2009 | 05:27 AM
Thanks everyone for your help, im taking it to our shop today, and gettin that sum' bitch out.
Old 06-16-2009 | 12:15 PM
starboy2nv's Avatar
First EVER K24 Turbo CL
h motors are overrated (if you have that swapped in)
njresendez
3G TL Photograph Gallery
09-21-2015 06:32 PM
Quick Reply: Help ASAP.
