flat tire arouses more problems
Old Jun 16, 2009 | 10:07 AM
QuentinRice's Avatar
Angry flat tire arouses more problems
So I got home and noticed i had a flat tire.. im trying to change it to my doughnut so I can get to a tire place and another problem arises.. Its my rear driverside tire.
When the Ebrake is on the tire still spins.. and its just about impossible to get the wheel off!! what do i do!!
Please help
Old Jun 16, 2009 | 10:27 AM
bRunCL's Avatar
you can start to loosen the lugs while the tire is still on the ground nd then jack it up and finish removing them. Not sure if this is what you are referring to tho, if not please explain.
Old Jun 16, 2009 | 10:29 AM
OttaWacK's Avatar
less n00bin more g00glin
^^^you dont need to loosen them too much. Just break them a 1/4 turn at most.
Old Jun 16, 2009 | 10:31 AM
yea I got it off and all.. but the problem is i dont understand why my tire was still able to spin when the emergency brake was up... Isnt it supposed to lock up both back tires
Old Jun 16, 2009 | 10:46 AM
on1wheel01's Avatar
i imagine it still spun because it is not workin properly.................................. either it needs to be tightened or the cable is stretched, or the e brake pads need replacing
Old Jun 16, 2009 | 11:11 AM
DaInFaMMuS1's Avatar
you can adjust ur ebrake to be tighter using the screws/bolts underneath ur armrest that's connected to it.
Old Jun 16, 2009 | 08:17 PM
DjXtC34's Avatar
check your breaks first ! before you go and start messing with your emergency break.
my opinion .....
Old Jun 16, 2009 | 08:22 PM
Anhedonia's Avatar
yeah, theres a little pin that locks the cable to the arm off of the caliper. check to make sure its still there. one of mine rusted and snapped, causing me to replace the entire assebmly, now i need to replace the springs that pull the arm back so i can actually use my ebrake without my calipers seizing.
TLDude876
Dec 28, 2016 03:18 PM
lland
Oct 4, 2015 04:47 PM
fallacy
Sep 4, 2015 10:15 AM
