Help!!! Amp and Subwoofer installation
Old Oct 17, 2004 | 05:08 PM
akinaboy's Avatar
Hi,
I am not an expert in sound system and wirings, but I have some knowledge of working on cars...
Anyways, I was trying to install an amplifier(Pioneer GM-400F) and Infinity silvercone woofer on a Sony Explod CDM-M620. For the remote wire, I tapped a blue wire with white stripe on from the back of the head unit and hooked up all (+) and (-). The power light on the amp came on, and I thought it was all ready to boom boom, but it did not sound..
Since it was 4 channel amp, I bridged them on the amp. Also, I treid many different way of wires, but did not work.
Can anyone help me out?
Any helpful info would be appreciated.
Old Oct 17, 2004 | 05:12 PM
Leon's Avatar
is there a switch on the amp that selects between stereo and bridged operation?
Old Oct 17, 2004 | 05:19 PM
BEETROOT's Avatar
Yeehaw
What do you mean you tried many different 'way of wires'. There is only one way... and you are running a 4 channel amp into one sub?
You might want to read up a little on installation basics. Crutchfield has some good info if you dig around... http://www.crutchfieldadvisor.com/
Old Oct 17, 2004 | 05:35 PM
Acura2.3CL's Avatar
check your amp...i beleive that most companies turn the gain all the way down when they are new.
Old Oct 17, 2004 | 10:45 PM
akinaboy's Avatar
oh..
thanks for your help..
I already figured it out..
The problem was RCA cables that goes into the amp.
I have installed sub and amp few times, but at that time, I did not have to use RCA cables and I only used remote cable from the factory cd player.
Well..
thanks a lot guys for your replies.
thanks.
Old Oct 19, 2004 | 09:51 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
Old Oct 19, 2004 | 09:52 PM
Hobo's Avatar
Flap.
whatever works for you
Old Oct 19, 2004 | 10:18 PM
ShibbyDevil's Avatar
Doom dee doooooom
he didnt use RCAs to carry the signal from the headunit to the amp
Old Oct 19, 2004 | 11:41 PM
Hobo's Avatar
Flap.
thanks :captainobvious:
Old Oct 20, 2004 | 08:59 AM
LCARUCA 97's Avatar
Trailblazer = SUCK
what did he use? osmosis?
Old Oct 20, 2004 | 10:28 AM
Slooo97CL's Avatar
where does everyone ground the amp too??!??!?!?!??!?!?!?!?!??!?! i have the biggest problems with finding a good ground in the trunk....someone take a pic and post it
Old Oct 20, 2004 | 11:20 AM
Hobo's Avatar
Flap.
i grounded it on the side behind the carpet on the left side of the trunk theres a metal brace, i just dremeled all the paint off and put a bolt through a an existing hole
Old Oct 20, 2004 | 12:15 PM
Acura2.3CL's Avatar
I grounded mine to one of the 4 speaker bolts coming into the trunk. I grinded the paint off the spot above the bolt then just got a nut that fits the bolt and thats it. Of course my amp is on the top of my box so it was a close spot to ground it to. It might not be as good if your amp is located somewhere else.
Old Oct 20, 2004 | 08:34 PM
Doom dee doooooom
he used nothing... thats why it didnt work
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
3GTLOwns
Sep 9, 2015 09:51 PM
