help...
Old Jan 23, 2007 | 07:01 PM
natesezgoblue's Avatar
help...
already searched but no luck...my key fob is broken an i need a new one..are they easy to re-program? how much is a new one? help would ne appreciated.
Old Jan 23, 2007 | 07:38 PM
AznX TL's Avatar
where is....
its easy to program, and they run around $25-30 for a used one off ebay.
Old Jan 23, 2007 | 08:56 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
here's the instruction on how to reprogram them...
Applications:
* 94 - 02 Honda Accord (all trims)
* 97 - 99 Acura CL (all trims/egines)
PROGRAMMING REMOTE TRANSMITTER
NOTE: Procedures must be performed within the stated time limits. Four
remote transmitters may be coded into system.
1. Turn ignition on. Within 1-4 seconds, press remote transmitter lock or unlock button while pointing transmitter toward keyless entry control unit. Turn ignition off within 1-4 seconds. Go to next step within 1-4 seconds.
2. To program another transmitter, repeat step 1). Four transmitters may be coded into keyless entry system. If more than 4 transmitters are coded, the first transmitter code will be erased. After all desired transmitters have been programmed, go to next step to verify system operation.
3. Within 15 seconds of programming final transmitter, press lock or unlock button. Verify that door locks operate and go to next step.
4. Check door lock operation using each transmitter. Turn ignition off and remove key. Remote transmitter codes are now stored in keyless entry system control unit. Reverify door lock operation.
Old Jan 23, 2007 | 09:32 PM
ZeroCL's Avatar
W WHIP.
djsense03TLS
Wash & Wax
Dec 23, 2018 11:10 AM
Skirmich
Sep 19, 2015 04:16 PM
nf3d0149ab
Wash & Wax
33
Aug 18, 2008 01:37 AM
doowop22
Wash & Wax
Aug 14, 2008 09:49 PM
buyingCLsoon
Aug 1, 2001 02:06 AM
