Help
Old Aug 28, 2004 | 09:42 PM
gmb2000's Avatar
Help
A friend of mine told me that there is a tool you can use to get the 2 screws off the rotors. He told me that you dont need an impact wrench to take the screws off.
Is this true? Help me out if you know of a tool to use.
Old Aug 28, 2004 | 09:45 PM
Hobo's Avatar
Flap.
just drill them out
Old Aug 29, 2004 | 03:47 AM
krazy99cl's Avatar
O.G.
u can drill them out but dont strip them.....just try the impact wrench....u can strip it with that too but not as much.....basically all it is, is hammering it and it turns......
Old Aug 29, 2004 | 03:49 AM
DanMan1464's Avatar
Autobot
breaker bar?
Old Aug 29, 2004 | 10:19 AM
sylthecru's Avatar
go to sears tools section the tool will be under the section with the screwdrivers. thats what you will need its like 19.99. one more thing. go to honda and buy some new screws that tool destroys the old screw. also i will need two more srews thats like a1/4 if not mistaken on the seize of te screw. those srew when treaded into the hole will pop the rotor off.
Craftsman 3 pc. Screw-Out™ Damaged Screw Remover Set
Sears item #00952154000 Mfr. model #52154
http://www.sears.com/sr/javasr/produ...id=00952154000
Old Aug 29, 2004 | 03:00 PM
wilp99's Avatar
or u could take a chizzel and hammer.
