Help!
Old Mar 27, 2003 | 10:54 AM
Epoc's Avatar
Stylin CL
Help!
After a few weeks of waitng to put on my shocks/springs/camber kit i just got a call from the place doing it saying that half of the stuff i brought them was wrong, it didnt fit. I had the springs on my car before so those are fine, with the camber kit they said that the rear would not work, junsure about the front. Something wlse was also mentioned about the shocks, going to find out more when i go pick my car up.
Here are the items i bought off ebay
camber kit
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2403790420
Shocks (i belive on the box the numbers were bu3714 and bu2896)
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2403778294
I thought these would work?
im going to find out exactly whaty was wrong with these parts and get back with you huys here, just a little pissed right now and venting...
Old Mar 27, 2003 | 11:02 AM
CLpower's Avatar
teh Senior Instigator
yes they all should work given that they are for the 90-97 accord which it says they all should work w/
Old Mar 27, 2003 | 11:16 AM
VXCL's Avatar
AWD Torque Monster
are u sure? i thinks a wrong info. do 90-93 accords share the same front and rear suspension?
also how much did u drop ur car? why are you using a camber kit?
Old Mar 27, 2003 | 11:23 AM
Epoc's Avatar
Stylin CL
2.5 front/2.25 rear I had this setup before with stock shocks and no camber kit and i ate through tires like you woulent beleave. I'm still waiting for my ride to get here to pick up my car and find out exactly what was wrong. Anyone used the sprint extreme camber kit before?
Old Mar 27, 2003 | 12:34 PM
Epoc's Avatar
Stylin CL
Ok, went ti pick up my car and here is what they said. The back camber kit would not work at all, and the front didnt look like it would fit either. As for the shocks they said that they looked like they would match up, however they were shorter than the stock ones. Im gonna goto a local import shop and see what they say about the camber kit.
Old Mar 27, 2003 | 12:58 PM
jamolie's Avatar
05 STi White/Gold
it depends if you have a 2.2, 2.3, or a 3.0 it should fit except if you have a 3.0. if you do, then you've bought the wrong one.
Old Mar 27, 2003 | 02:19 PM
CLpower's Avatar
why would he of gotten the wrong one on a 3.0?
What do you mean they said it looked like it shouldn't fit? They didn't even try or what? I have a feeling these guys are idiots
Old Mar 27, 2003 | 03:02 PM
Epoc's Avatar
Stylin CL
ive got a 2.2 and i took a look when i got home and the rear is completly different, also when i got too looking into the instructions that came with the kit, the instructions dont cover the right part number for my car. The instructions for the front do cover the correct part number that i need. When i talked to the guy he said that the rear was completly wrong and the front most likely wouldent work either. I'm going to e mail suspension max and also ake my car somewhere elso for a diffrent opinion.
Old Mar 27, 2003 | 03:23 PM
CLpower's Avatar
sorry that you are having so much trouble, i know how discouraging this all can be
Old Mar 27, 2003 | 03:26 PM
Cseika's Avatar
Watchou OUT on those stuff on EBAY!! sometimes they give u the wrong info... and just for your information the 90-93 accords are NOT THE SAME as the 94-97 accords..... therefore.. the info on Ebay is WRONG!!! tell the guy that and see if he would give you a refund....
I got an OBX crankpulley that saids 90-97 accords... and it didn't fit on my 2.2 either... it went on perfectly on my friends 91 accord..
Old Mar 27, 2003 | 03:47 PM
Epoc's Avatar
Stylin CL
well, the part number wont even fit a 90-93 accord for the rear. The instructions i got were for the part numbers for a 90-93 integra 94-00 integra and a 92-95del sol and 96-00 civic...not even close to a cl. I emailed the company, and if i need to ill give them a call to try and get the correct kit. I just have this sudden urge to start hiting various items with a baseball bat.
Old Mar 27, 2003 | 07:51 PM
Epoc's Avatar
Stylin CL
Well, after countless emails, the company rep determined that i had the wrong rear camber kit (no fuckin shit). Even though its past the time allowed for an exchange they agreed to exchange it anyway. As for the front the rep said that all hondas and acuras use the same anchor bolts.
