help with 18s
Old Nov 7, 2001 | 04:24 PM
indopinoy's Avatar
very punny....
help with 18s
still shopping, called a shop today for some racing hart evos, but he told me because the cl needs a 48 offset that all the evos will rub fender(because they dont make offset thay high), especially on lowered cars. is this true? does anybody with evos have this or any problems?
Old Nov 7, 2001 | 04:41 PM
MikeSwing's Avatar
Mas Italy 18's
I have the Mas Italy 18's which are 18x7.5 with a 45mm offset. They fit perfect and no rubbing at all evne though it's not dropped yet.
Old Nov 7, 2001 | 05:03 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Re: help with 18s
If you really want them...get them....roll the fenders....that's what I plan on doing if my rims don't fit....the price you pay for individuality..
Old Nov 7, 2001 | 05:21 PM
BlazinCL's Avatar
I.B.E.W. local 3
I have 18x7.5 Axis Se7ens(42 offset) with a 215/40/18 pirelli tire, on drastic drop using the Eibach sportlines...I have NO problems at all... I would try to use the same combo as I did, im very happy with my combo
Old Nov 7, 2001 | 09:26 PM
R1Performance's Avatar
Power of Dreams
You might want to check with other shops because I think the 1st gen CLs and 5th gen Accords typically use a 40-45mm offset w/ larger wheels.....I think a 48 offset will put you really close to rubbing on the inside....correct me if I am wrong.
Old Nov 7, 2001 | 09:36 PM
jdf0-cl's Avatar
9th Gear
I just ordered 18's with a 40mm offset and was told they would fit perfectly with a 225/40 tire. The offset was my main concern cause I am planning on putting the Eibach Sportline kit on in a couple months. I will let you know when I get them mounted.
TSX 09
33
Oct 25, 2015 01:32 AM
Crazy Bimmer
Feb 7, 2006 09:36 PM
cljosh
May 4, 2002 12:19 AM
cljosh
Apr 7, 2002 03:15 PM
Water-S
Sep 1, 2001 06:11 PM
