Heated Mirror Switch
Old Mar 2, 2004 | 11:31 AM
RCB1701's Avatar
I have an 1998 3.0 CL with 112K, and the heated mirror switch light only stays on while holding the button down. The dealership wants $120.00 for a new switch, uninstalled. Has anyone else had this problem with their heated mirror switch? I am really suprised that this switch is already worn out considering that it is probably the least most used switch in the car. Thanks in advance for the feedback.
Old Mar 2, 2004 | 11:58 AM
Stewie_RENAMED's Avatar
Same thing happened to me.
I never bothered to fix it.
Old Mar 2, 2004 | 12:25 PM
DanMan1464's Avatar
Autobot
I've never tried my switch before, since I park in the garage my mirrors never need to be heated....Maybe I should see if it does the same thing. I think I remember that the button was sticky on the outside a little bit, making some resistance to push the button.
Also, sorry to jack the thread, but the window switches etc dont' have LED's....is there any way to connect LED's to the heated mirror switch? So that you have to turn on the heated mirrors for the LED's to activate under the window switch etc...It gets kind of annoying at night since I have to feel for the right switch at times.
Old Mar 2, 2004 | 02:08 PM
wilp99's Avatar
does the heat accually work. i think theres a bulb behind the switch. i know every time i take out my heated seat switches the bulb stops working. maybee it just needs to be adjusted alittle.try pushing in on the bulb. if it still
Old Mar 2, 2004 | 04:54 PM
RCB1701's Avatar
If the light is not on it will not emit heat; therefore, I have to hold the button down until the ice melts.
Old Mar 3, 2004 | 06:03 AM
After reading this post I checked mine again.
Now the light doesn't go on at all, even if I hold down the switch.
Since my car is garaged I never used it anyway.
Old Mar 3, 2004 | 10:04 AM
christopher g's Avatar
Same thing happened to mine a week ago!!
My switch only worked if i held it down, there is obviously something wrong with the design of the switch.
Now if I hold it down the light does not even come on and they don't work!
i was thinking of ripping it out and checking the contact.
2.3 98 cl
Old Mar 3, 2004 | 08:45 PM
MikeSwing's Avatar
Someone on this forum said they knew how to fix it but I can't remember who or how. Help us.
Old Mar 3, 2004 | 11:26 PM
liloj's Avatar
i like orange juice
my switch only lights up when its pressed down....i dont have to hold it down though......it stays down by itself and lit up.....
Old Mar 4, 2004 | 11:10 AM
Same thing here this is definately a problem with all the cars
help help!
Old Mar 4, 2004 | 03:48 PM
3.0VTECboy's Avatar
i've never heard of that prob before. now you guys have me worried...:/
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
