Headlight not working...what could it be??
DamnThisHobby'sExpensive!
hey guys...well my headlights not working...yes the 9006 bulb...i tired 2 bulbs and they both dont work...im gonan try another bulb tomorrow but im now thinking its not the bulbs thats the problem...could it be the wiring? how could i test this and would it be easy and cheap to fix?? got any ideas on what to do or how i could find out that the problem is??
You also might want to check the fuse for the headlamp in the engine compartment's fusebox.
Might have blown out, short circuited somewhere, maybe from getting wet, raining lately?
-James
-James
ENGAGE MY VTEC BABY!!!!!!
try the fuse, take to kregans and see if you are getting current(power) to the headlight, if you are maybe its not the fuse cause if you get power the fuse shouldnt be blown right?
check it out, did you try the stock bulbs? or are they aftermarket?
tried stock bulbs....i have had a problem with water leakin in that one headlamp lately...so maybe its the fuse.??...i'll see...thanks!
what the hell is kregans?? lol
soo say it is my fuse....how can i tell if the fuse is broken?? isnt there like a little metal strip that if its broken in 2 then its a bad fuse?? is the fuse in the same fuse box by the drivers feet??
No this fuse is under the hood to the left in the engine bay. There's a large plastic cover over the fuse box. The fuses are blade fuses so once removed see if the metal filament was fried. If so that's your prob, replace it and it should work fine.
*Edit* The fuses should be 25 amps. Also if you do replace them and they still burn out your gonna have to trace your headlight wires and see if they're open and touching the chassis. It's grounding somewhere and short circuiting.
thanks...i figured it out...i just had bad luck...the fuse was bad, and then after i replaced that, i tried another bulb and that didnt work ..."so im thinkin ohhh grreeatt" then i try another bulb...still didnt work....and just outta luck, i find one more bulb i have and it DID work...so for some reason, theose 2 bulbs wernt working which was freakin me out givin me back luck...but im fine now...
lol...although it looks a little ghetto...i have a blue 9005 in one and a OEM 9006 in the other...hehe their different colors. . .but i guess whatever works until i can get another new bulb...
AmplifiedDetails
09-24-2015 02:55 PM
